Activity › Forums › Apple Final Cut Pro › Stopping compressor mixing down Audio Roles Export
  • Stopping compressor mixing down Audio Roles Export
    Posted by James Bayliss-smith on November 11, 2012 at 3:54 am
    Hi there, I need to compress files using compressor to send stories for news broadcast. I export two audio track using FCP’s roles feature so they can re-edit my stories into shorter versions. When I compress to Mp4 using a program called newscaster that we use to send stuff it maintains these distinct audio files. However U would like to use compressor as I think the quality of the compression is better (with the same settings)
    So I am trying to compress to mp4 using compressor and it seems to mix down these roles into one track of mono audio or a mixed stereo pair. Is there any way to use compressor to make a mp4 without having it mix down the tracks? This would be very useful to me, any ideas. It seems I need mp4 as they never seem able to open my stuff when I send it over as a .mov (they are on some windows editing program I’ve never heard of)
    I’m using FCPX 10.0.6
    Compressor 4.0.5
    osX 10.8.2
    Jeremy Garchow replied 13 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Paul Figgiani
    November 11, 2012 at 2:02 pm
    James,
    Not sure if this will help but have a look:
    https://f-video.s3.amazonaws.com/sep-files.mp4
    Notice in the “Roles As” popup I set “Audio Roles Only as Separate Files.” This is going to give me 6 independent mono files. In FCP X, I assigned Roles to each channel. I used L, R, C. LFE, LS, RS. I defined these in the share dialog and set file(s) channel format to Mono. Of course in your case you’ll need to set up the video export as well.
    -paul.
  • Jeremy Garchow
    November 11, 2012 at 6:52 pm
    If you need to keep it as one multichannel file, you select the “Roles as multichannel Quicktime Movie” in the settings tab and route the Roles appropriately.
    Jeremy
  • James Bayliss-smith
    November 11, 2012 at 11:34 pm
    Thanks for your response guys. I do already export roles as multitrack QuickTime file. The problem is that when I compress them in compressor it mixes down the tracks into a stereo or mono mix. I could make separate video and audio files based on my roles as the first response suggests, but then I would have to send several files. This is not practical in a news environment where speed is often required. I can see them losing certain files etc. it needs to be one file. As I said we have a program specifically designed for news organisations and (as long as you only have two tracks of sound) it keeps the tracks distinct after the compression . The problem is I cannot tweak the settings and so I would prefer to use compressor. Can compressor do this or do I need another compression program!
    There is a workaround. say for example I group all my audio into two roles. I select all the clips in one role and pan the stereo to the left. I pan all the other ones to the right. Then when I export and compress the tracks maintain there own sounds without being mixed down. This is fine but I want to use the roles function (as I have been doing for ages) but for various reasons I want to start compressing in compressor.
    As a little aside is there any way to select all clips tagged with a certain role without individually selecting each one?
  • Jeremy Garchow
    November 12, 2012 at 12:55 am
    James-
    What format exactly are you compressing to?
    Why not just use FCPX to do this? It’s the same engine?
    If you do need to use Compressor, can you set the audio to “passthrough”?
    [James Bayliss-Smith] “As a little aside is there any way to select all clips tagged with a certain role without individually selecting each one?”
    In the timeline index (shift-command-2) type in the role name in the search bubble with the “clips” option selected. That should return all the clips with that Role, then select them in the TL index.
    Jeremy
    November 26, 2012 at 6:25 am
    [Jeremy Garchow] “What format exactly are you compressing to?”
    mp4 using the H.264 bassline profile in Compressor’s MPEG-4 settings window
    [Jeremy Garchow] “Why not just use FCPX to do this? It’s the same engine?”
    I have been using FCPX to directly export using compressor settings but compressor mixes down my roles upon compression, unlike if you export a multi-track quicktime file full quality from FCPX
    [Jeremy Garchow] “If you do need to use Compressor, can you set the audio to “passthrough”?”
    Not sure how would one do this?
    November 26, 2012 at 6:29 am
    Not sure how would one do this? There is a checkbox that says “Audio Enabled” I guess if I uncheck this then it won’t touch the Audio? Bingo that may solve my problem I’l try it out
  • Jeremy Garchow
    November 26, 2012 at 4:31 pm
    <[James Bayliss-Smith] “mp4 using the H.264 bassline profile in Compressor’s MPEG-4 settings window”
    Got ya. Yes, MPEG4 is stereo only in compressor when using the MPEG4 dialogue.
    I know in Episode, you can channel map. Compressor has never had this capability.
    You can export and h264 .mov with Roles as a multichannel QT. Not sure if that will work for you, though.
    Jeremy
