Activity Forums Adobe After Effects Expressions Stopping a loopOut() expression at a certain frame
  • Stopping a loopOut() expression at a certain frame
    Posted by Marcel Birkel on March 22, 2019 at 11:36 am
    Hello Creative Cow community,
    I’m working at the moment on a train animation in After Effects.
    So I looped the rails and stuff with the “loopOut()” expression.
    (I looped them because I don’t wanted a 5000000 pixel long comp lol)
    What I want to do is that the loop stops, at e.g., 2000 frames smoothly (easy-ease).
    I tried to use the freeze-frame effect, but it won’t work and keeps looping.
    Taking a screenshot of the comp and put it on the place where the loop should stop works, but it’s too abrupt.
    I also tried the solution from there -> https://forums.creativecow.net/docs/forums/post.php?forumid=227&postid=20810&univpostid=20810&pview=t
    But it won’t work for me.
    Can anyone help me please?
    Thanks in advance,
    Marcel
    loopOut()
    Dan Gehin replied 6 years, 1 month ago 3 Members · 2 Replies
  • Oleg Pirogov
    March 28, 2019 at 11:33 am
    Well that quite an elegant solution, which in your case I guess will look smth like that:
    t = timeToFrames(2000);
    fadeTime = 1;
    ease(time,t,t+fadeTime,loopOut(),value)
    I would suggest to try to figure out why it doesn’t work in your case, but anyway you can always go rigth-click on looped-out property -> Keyframe Assistant -> Convert Expression to Keyframes and do all the things manually.
  • Dan Gehin
    July 30, 2020 at 5:55 pm
    fadeTime = 1;
    The conversion is backwards: timeToFrames should be framesToTime
    t = framesToTime(2000);
    fadeTime = 1;
