Activity › Forums › Adobe After Effects Expressions › “Stopping” a delay effect?
  • “Stopping” a delay effect?
    Posted by Anna Karlsson on January 28, 2022 at 2:58 am
    Hi!
    I’ve animated a comp that moves between four position keyframes and repeats a couple of times through loopIn.
    The problem is that I have six additional comps that I want to follow the original comp like a train. Using the delay expression I get the effect I’m after during the loop, but when loopIn reaches its end the “leader” stops and the remaining 6 comes crashing into it.
    Is there a way to stop the remaining 6 in their tracks when the first one stops? Almost as if it were a train with connected carriages? So that they are divided evenly over the four position keyframes, and not colliding into the last?
    Andrei Popa replied 4 years, 7 months ago 3 Members · 4 Replies
  • Filip Vandueren
    January 28, 2022 at 10:58 am
    The easiest fix is to precompose leader and followers and timeremap this to achieve the looping and stopping.
  • Anna Karlsson
    January 28, 2022 at 12:14 pm
    But that will affect the timing of the animation in the precomps as well (right?), which I don’t want! :/
    I’ve tried the “follow the null” suggestion on this page: https://www.motionscript.com/mastering-expressions/follow-the-leader.html, and it positions the followers as I want but I can’t get them to follow the leader. Could it be because it’s made especially for 3D-layers and I’m working with 2D?
  • Filip Vandueren
    January 28, 2022 at 4:14 pm
    Yes, that’s true: I didn’t account for the fact the individual layers were animating.
    Dan’s expressions should work for 2D, but I’m not sure if they work with loopIn().
  • Andrei Popa
    January 29, 2022 at 9:38 am
    I think you can put an if with time you want them to stop. Something like this:
    if(time <= endAnimation){
    //the expression you are currently using
    }else{
    valueAtTime(endAnimation)
