Activity › Forums › Apple Final Cut Pro Legacy › “STOPlight” – Caution when upgrading to Tiger…
Posted by Skychase on May 19, 2005 at 1:06 amhttps://macintouch.com/tiger16.html
It seems whenever a firewire drive is plugged in, it must be reindexed for Spotlight, even if already indexed by that Mac. No way to turn indexing off. Large drives can take a very long time, and while indexing the drive is not usable for editing/capture. Some now call it STOPlight!
Skychase replied 21 years, 3 months ago 8 Members · 9 Replies -
Tom Matthies
May 19, 2005 at 3:26 amI experienced this last night with a pair of striped FW800 drives. This could be a problem…it takes quite a long time.
Anyway to disable Spotlight without limiting accessability to the drives or disabling the “old fashioned” CMD-“F” find function? While it’s a neat feature, I just don’t need it right now.
Waiting for FCP5 to show up soon. Installing it on a brand new G5 with Tiger. I will, however, be keeping my old G4 system online… just in case.
Tom -
Solie Swan
May 19, 2005 at 4:35 amSee my post further down about FCP workflow under tiger. Either you have to drag your external drive into the privacy tab every single time you mount it (and then it is best to check activity monitor to make sure that it really has quit indexing) or run the terminal command to stop indexing.
Do you want SL indexing your 1 TB external drive everytime you start digitizing media? But if you put it in the privacy tab and you need to find a file fast (the client asks you to pull up version 3 of their logo they sent you 7 months ago) on that drive, you can’t use SL (and command F does not seem to work on drives that are put in the privacy tab either.) I am sure that Apple will get around to fixing this at some point but till they do it is an annoying workaround with limitations. -
Walter Biscardi
May 19, 2005 at 7:21 am[Tom Matthies] “Anyway to disable Spotlight without limiting accessability to the drives or disabling the “old fashioned” CMD-“F” find function? While it’s a neat feature, I just don’t need it right now.”
According to the article that was linked to above, the answer is “no” spotlight cannot be disabled.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Skychase
May 19, 2005 at 2:31 pmMore on STOP Light at Macintouch:
https://macintouch.com/tigerreview/spotlight.html
Endless Indexing-
Spotlight’s indexes are maintained by the Tiger behind the scenes. Unfortunately, some users have discovered the ‘mdimport’ process sucking up nearly all their computer resources, apparently reading files from disk for indexing, but running for days and not finishing. Unlike initial indexing when Tiger is first installed, the Spotlight menu is available for use in this scenario, but does not return complete results. Apple Mail and Finder searches also may fail to return full results.
Chris Poisson
May 19, 2005 at 2:54 pmWith my Dual 1.42 G4 and Tiger I have had no FireWire problems, I have a LaCie 500 gig Big Disk Extreme, a Maxtor 250 gig FW400, and a Promax 500 gig two drive RAID hooked up to it. None of the above problems.
Go figure…
Matthew Abourezk
May 19, 2005 at 3:20 pmBut have you disconnected those drives at any point, ran your machine for a while… then reconnect the drive at a later time? I think THAT is when you would notice the problem.
Mitchji
May 19, 2005 at 3:46 pmHi,
Spotlight can be turned off for individual Volumes in the Terminal. This could be in a script that runs at startup. It can also be turned off entirely. Here is more information that was originally posted on Macfixit:
Spotlight processor usage and performance problems We continue to cover an issue where Mac OS X 10.4’s Spotlight function consumes inordinate amounts of processor time, resulting in slower overall system performance or seemingly complete systems stalls.Note that the issue covered here is separate from performance problems within Spotlight itself, such as the normal function where Spotlight begins a search during the string typing process, resulting in system unresponsiveness for a few seconds.
Solutions
Giving Spotlight processes less priority via “renice” For some users, giving Spotlight processes less system priority via the “renice” command results in better overall system performance, though performance from Spotlight itself may suffer.
The easiest way to perform this process is to enter the following command in the Terminal:
* renice -n (new renice setting number) -p (process ID number)
The higher the renice setting number (up to 20), the lower the process priority. The process ID number for various Spotlight operations can be found using Activity Monitor (located in Applications/Utilities). The most implicated process is “mds” — launch Activity Monitor, and note the process number next to “mds.”
* renice -n 19 -p NNN
(where NNN is the process number received from Activity Monitor. You can also get the process ID for “mds” with the Terminal command “ps -acx | grep mds”)
This can also be accomplished with the freeware utility BeNicer. After downloading an launching this application, enter “root” as the user and select the “mds” process, then change its renice setting to a higher number (18 or 19).
Temporarily disabling Spotlight and re-launching Another workaround that has proved successful for some users is simply turning off the Spotlight indexing process for installed volumes then turning it back on.
MacFixIt reader Jeff Hirsch has instructions for doing so in the Terminal:
1) Using the mdutil command-line utility in Terminal, turn off indexing for each of your drives. Example:
* $ sudo mdutil -i off /Volumes/your_hard_drive_name_1
* $ sudo mdutil -i off /Volumes/your_hard_drive_name_22) Then use mdutil to remove the indexes from each drive
* $ sudo mdutil -E /Volumes/your_hard_drive_name_1
* $ sudo mdutil -E /Volumes/your_hard_drive_name_23) Physically remove the .Spotlight directories from the root of each drive.
* $ cd /
* $ sudo rm -fr .Spotlight-V100(do the same for your second or third drive)
Make sure to carefully type the “rm” command — a typo could result in deletion of critical files.
4) Use mdutil again to turn indexing back on for each drive
* $ sudo mdutil -i on /Volumes/your_hard_drive_name_1
* $ sudo mdutil -i on /Volumes/your_hard_drive_name_25) Spotlight will now re-index all drives and should behave in a normal fashion. (No longer uses 60%-80% of your CPU)
Turning Spotlight off completely Simply killing the mds process or other Spotlight-related processes in Activity Viewer, or using the above disabling process, will not keep Spotlight components from continuing use of excessive system resources for some affected users.
In this case, you can turn Spotlight off completely by editing Mac OS X’s hostconfig file, which determines the system components that are loaded at startup.
First, enter the Terminal and use the command:
* sudo pico /etc/hostconfig
to open the hostconfig file in the “pico” text editor. (For more information about using pico, type the command “man pico” in the Terminal).
Scroll down the hostconfig file and file the line that says “SPOTLIGHT=-YES-” and change it to: “SPOTLIGHT=-NO-” (without quotes).
Exit pico, saving the file, and restart Mac OS X. Spotlight will no longer launch at startup.
To go one step further and remove Spotlight from the menu bar, remove the file “Search.bundle” from the folder /System/Library/CoreServices (move it to the Desktop or another external location) and again restart.
Disabling indexing for certain folders For some users, simply turning off Spotlight indexing for particular problem folders will resolve performance issues.
For instance, the mailbox folders used by some e-mail applications will be re-indexed every time a small change is made, resulting in spikes in processor usage.
MacFixIt reader Johan Solve writes:
“I’m also experiencing high processor usage and much hard disk grinding in Tiger, and I think it’s Spotlight-related. It got a bit better when I excluded my Eudora folder from Spotlight indexing, where large mailbox files would get reindexed every time a mailbox was modified by new messages.”
Folders can be excluded in the “Spotlight” pane of System Preferences in the “Privacy” tab. Simply click the “+” button in the lower left corner and select the folder to be excluded, or drag the desired folder to the list.
Possible causes for Spotlight problems Meanwhile, one MacFixIt reader offers some possible explanations for why Spotlight is problematic on some systems and not others:
“My initial indexing process after installing Tiger was interrupted by a couple of reboots I had to do while installing third-party apps. This may have left me with a funky index when Spotlight tried to pick up where it had left off. I suggest letting it fully index your drives before rebooting the machine at all.
“A few users in the Discussions over at Apple noticed that they had files on their hard drive with modification dates after the current date. i.e. days/months/weeks into the future. These files may have been causing Spotlight to choke as it tried to make sense of a date that hadn’t happened yet.”
Best Wishes,
Mitch
Kevin Morrison
May 19, 2005 at 6:35 pmHmm. I am using Tiger and FCP 4.5 and having no problems with Spotlight slowdowns. I take a drive from home to work and back each day, so I am constantly plugging and replugging a 250 GB LaCie firewire drive…
Skychase
May 21, 2005 at 2:36 amHere is a new bit of Freware called Spotless – a simple utility designed to disable or enable Spotlight’s auto indexing with the click of a button.
https://www.versiontracker.com/dyn/moreinfo/macosx/26842
