Activity › Forums › Apple Final Cut Pro Legacy › STOP THE CAPTURE
STOP THE CAPTURE
Posted by Bob Vick on May 12, 2005 at 6:54 pmIs there a way to exit the capture process and NOT have the material capture to that point be saved?
b
Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
Bob Vick replied 21 years, 3 months ago 3 Members · 5 Replies -
Kevin Monahan
May 12, 2005 at 11:29 pmOn Batch Capture? ESC.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com -
John Fishback
May 13, 2005 at 3:53 pmIs there a way to stop capturing a clip with an in and out, earlier than the out, and NOT lose the clip?
John
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
Kevin Monahan
May 13, 2005 at 5:29 pmNot that I know of. Isn’t that why you log anyway? To actually find your out, or am I missing something? OR are you one of those folks that logs to capture an entire tape roll?
Kevin Monahan
fcpworld.com -
John Fishback
May 13, 2005 at 5:45 pmI usually log and capture scene by scene. There are times, however, with a longer clip that I decide I’d like to bail out early, but keep what I’ve captured to that point. When I used to edit with Media100, that was an option when capturing. You could stop or abort.
John
FCP4.5 DVDSP 3.0.2
Bob Vick
May 13, 2005 at 6:49 pmI knew that. I should have specified during Capture Now. There are times when “slammin’ a spot together, I will scan the tape and find what I want label it, roll the tape and capture. So to abort the capture would be great but not a deal breaker.
Thanks for the feedback
b
