Activity Forums Apple Final Cut Pro Legacy Stop stretching of 16:9 footage on a 4:3 TV???
  • Stop stretching of 16:9 footage on a 4:3 TV???
    Posted by Andrew on June 30, 2005 at 3:33 am
    What is the truest way in FCP to make 16:9 appear as such on a 4:3 TV without it stretching? I’m doing a dubb out off the timeline to VHS.
    Thanks a lot
    Andrew
    Byrd Mcdonald replied 21 years, 2 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    June 30, 2005 at 3:59 am
    One way is to select a clip into the viewer, hit the motion tab, twirl down the distort options, and set the aspect to -33.
    Is your footage 4:3 true anamorphic, or is it digital anamorphic ie from a dv camera such as a pd 150?
    i did this very same process today with 4:3 anamorphic footage (downconverted from HD).
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Chris Poisson
    June 30, 2005 at 1:06 pm
    Andrew,
    You also can nest your 16×9 sequence into a 4×3 sequence and it will automatically letterbox it. Read this:
    https://www.kenstone.net/fcp_homepage/understanding_16_9.html
  • Byrd Mcdonald
    July 4, 2005 at 7:42 pm
    A tangent question about 16.9
    I just cut a 16.9 show for a client that has previously been skittish about the format. We only convinced the client to shoot and post in 16.9 because the video will be playing at a convention that has wide screen plasma monitors as playback.
    My question is how to handle the fact that, while the premiere venue for the video will be a 16.9 monitor (and thus, I will lay off my show as an anamorphic show that will play right on a 16.9 plasma, how do I handle a lay off for the rest of the clients needs, i.e. DVD dubs of the video. Do I simply lay off both shows on the master, labeling them “anamorphic” and “letterbox?”
    Strangely confussed about how NOT to make this difficult for the client.
    Byrd
