stop-motion using stills from digital camera
Posted by Esotericsean on November 9, 2006 at 7:16 amWhen you add a still shot to Vegas, it automatically sets its length to 5 seconds. Does anyone know how to change this default or know of any way to add stills to create an animation?
I’d like to be able to set the default to 1/24th and just drag and drop a whole folder of stills into Vegas.
Sean
Jerry Waters replied 19 years, 10 months ago 5 Members · 8 Replies -
Peter Wright
November 9, 2006 at 1:17 pmOptions > Preferences > Editing > New Still Image Length
Needs to be set BEFORE you drop the stills on the timeline.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Jerry Waters
November 9, 2006 at 2:24 pmFor animation number the stills sequentially. Then “File-Import” and choose the first numbered still. Then check the little box (lower left) to import the string. It will add the string as a video file.
If you want to get a feel for this, first export a short piece of video as stills. This is a little wierd but it is under “Tools-Scripting-Render image Sequence.” Vegas will send out the video as a group of 1 frame jpeg or png files in a sequence. Check those out. You want to do something like that to do the animation.
I know this is odd. It seems like Vegas should have “Import-Export” instead of two different areas for inbound and out.
JerryW
Jerry Waters
November 9, 2006 at 2:34 pmOn that “Import” it is “File-Import-Media” — then select the first still and check the box at the bottom for the numbered stills
JerryW
Edward Troxel
November 9, 2006 at 2:39 pm -
Esotericsean
November 9, 2006 at 5:26 pmthat does seem like the best way to do it, but for some reason vegas gives me an error when i send it a string of jpegs. (Warning: An error occurred while opening one of more files. The item was not found.)
thanks so much for all the help. i hope i can figure this thing out.
Jerry Waters
November 9, 2006 at 11:18 pmSorry it didn’t work for you but it does work – just quirky. The files would have to be compatible as to resolution etc. Just a thought — try numbering them in the same manner as Vegas when it exports them. In fact, try saving your files with their names.
JerryW
