Activity Forums Adobe Premiere Pro Stop motion using DSLR images
  • Stop motion using DSLR images
    Posted by Pieter Helsen on July 20, 2009 at 8:38 pm
    Hello all,
    I just took about 1200 images at an interval of 2 seconds, and now I want to make a stop motion movie out of those. Is Premiere the way to go (and if so, how do I go about it?) or am I better off with another program?
    I’m using a PC. (so I can’t use iStopmotion :))
    Kind regards,
    Pieter
    General notice: from now on, I would like to ask everyone to put [AS2] or [AS3] (corresponding to the version of actionscript you are using on your project) in front of their post titles when the question is actionscript related! Please help us help you faster. Thank you.
    Andy Carrasco replied 15 years, 10 months ago 5 Members · 6 Replies
  • Micah Mcdowell
    July 20, 2009 at 9:58 pm
    You definitely could use Premiere…
    Or, you could take Adobe After Effects if you have it and drop all your images in a composition, scale them and trim them all to 1 frame at the same time while they’re all selected, and then go to Animation>Keyframe Assistant>Sequence Layers.
    And, voilà, you’re done with your project. That method would take 30 seconds, while in Premiere you’d have to scale every frame individually (unless there’s a better workflow I don’t know in Premiere).
  • Jeff Brown
    July 21, 2009 at 1:55 pm
    I’d pre-process the images first in Photoshop if needed. Then, treat the images as a file sequence (assuming they have sequential frame numbers). Interpret the footage to the desired frame rate. I’d use AfterEffects for the finishing over Premiere; Premiere tends to bog down with large frame sizes (2K+), and color-correction, blurs, masks, etc, are probably easier to do in AE.
    -Jeff
  • Pieter Helsen
    July 21, 2009 at 3:24 pm
    Cool, thanks for the tips guys 🙂 I will use Lightroom and After Effects I think!
    Kind regards,
    Pieter
  • Ann Bens
    July 21, 2009 at 9:41 pm
    In the Preferences you can set the still image default duration to any amount of frames.
    If you set it for 1 frame the 1200 stills will give you a sequence of 48 seconds in PAL or 40 seconds in ntsc.
    Best is to convert the stills to framesize. This can be done in Photoshop as a batch.
    You also can scale the still down to framesize by scaling down one still, copiyng it in the timeline, selecting all the others and paste attributes. This will be a strain on you computer.
  • Jeff Brown
    July 22, 2009 at 1:16 pm
    One caveat: if you use still frames (as opposed to a file sequence), you’ll find it pretty much impossible to edit. You will have the equivalent of 1200 “clips”, all of one frame duration…
    been there ;>)
    Jeff
  • Andy Carrasco
    November 5, 2010 at 1:17 am
    Peter,
    I realize I am over a year too late for posting to this thread but I am working on a similar project in AE and would love to hear how you got yours to turn out. My main issue right now is rendering. My final video is choppy and doesn’t have a smooth transition between frames. If you could give me any insight on how you completed your project I would greatly appreciate it.
