Activity Forums Apple Final Cut Pro Legacy Stop motion frame rates & fcp
  • Stop motion frame rates & fcp
    Posted by Anna Odell on October 8, 2009 at 1:30 am
    hi there,
    i’m working on a stop frame animation using stop motion pro. the image sequences have been captured at varying frame rates – 24fps, 12fps, 15fps.
    we’ve now exported the sequences to Apple pro res 422 using QT. all the sequences were exported at the current frame rate.
    the sequences have been taken into fcp to edit. everything looks fine in fcp but i wondered if the varying frame rates are going to cause any problems further down the line – when we export the final movie or during the transfer to tape?
    Anna Odell replied 16 years, 10 months ago 3 Members · 3 Replies
  • David Bogie
    October 8, 2009 at 8:40 pm
    You’re going to have numerous problems, I think. I’m wondering why or how you thought you could get away with shooting still frame animation at different frame rates.
    An object that is designed to use one second of screen time to move across the screen will do so in one second regardless of the number of frames you shot to do the move. If you shot too many frames, you wasted your time because the frames are going to be discarded. If you didn’t shoot enough frames, the object will complete its move earlier than planned. You can’t just apply a speed adjustment and make the clip longer.
    bogiesan
  • Antoine Rocha
    October 8, 2009 at 11:40 pm
    Hi I’m having a heart attack.
    I need to send a client this 1 minute animation, which I made in AE CS3,
    exported as a (.mov) and placed it FCpro to match real time audio and some time issues in the animation. I started to cut the video and speeding up and slowing down some parts of it, directly in the edition. But at the third time that I rendered, the cursor (in a MAC) start to look like its freezing and a message appear, something like that I have to turn off the “unlimited RT” and some other issues. First of all “what a hell is that” to me it seams that is a memory issue, but I have enough resources, that the video is there but with no image or preview, now I can’t see anything, the render it won’t work. I restart FC and the machine “3 times and nothing!!” and when I try to exported and error occurred.
    I create a new project from scratch and rename the mov file and it seems to work, but when I tried to render for the first time the same thing happened AGAIN!!
    HELP!!!!
    I have tree dedicated hard drives with enough space, and a decent ram.
    Is the first time that something like this happened!!!!
    The video size is 3.5 gigs, but I don’t thing that is an issue…
    Please I need some advise I need to finish this video ASAP.
    THXS
  • Anna Odell
    October 9, 2009 at 8:42 am
    hi dave,
    thanks for your reply.
    the final output is PAL’s 25fps, HD.
