Activity Forums Apple Final Cut Pro Legacy stop motion effect
  • stop motion effect
    Posted by Frank Miller on June 18, 2011 at 6:56 pm
    Hi
    I’d like to create a stop motion effect by being able to have each frame in my sequence run for half a second.
    I can cut each frame, copy it, and paste it in 15 times – and that gives me exactly the look I want – but it will take me a million years to do it by hand.
    I’m guessing there’s a much simpler way – can any of you help?
    f
    Frank Miller replied 15 years, 2 months ago 3 Members · 3 Replies
  • Rafael Amador
    June 18, 2011 at 9:15 pm
    Hi Frank,
    try the “Strobe” filter set at “15 frames”.
    rafael
    http://www.nagavideo.com
  • Mike Molenda
    June 19, 2011 at 5:25 pm
    Effects > Video Filters > Time > Strobe
    This filter should do what you’re looking for, the footage plays back at regular speed, but skips a specified number of frames. I’m playing around with the settings on 24fps footage, and a Strobe Rate setting of 4 skips about 15 frames, while a setting of 5 skips half a second (12 frames at 24P). One of those settings should do the trick for you. If not, play around with the sliders until you get what you want.
    If you’re looking to do a slow-mo stop motion effect, right click the clip, select Change Speed…, and set it to 6.67% (6.67% of 30 fps = about 2 fps). Be sure to uncheck Frame Blending to get that jumpy look you’re going for.
  • Frank Miller
    June 20, 2011 at 4:45 pm
    Thanks – this is exactly what I needed.
    f
