Activity Forums Adobe After Effects Stop Motion by eliminating frames
  • Stop Motion by eliminating frames
    Posted by Alfonso Gamez jordano on December 21, 2007 at 10:18 am
    Hi.
    Suppose I have a normal shot, and I want to make it look like this:
    https://es.youtube.com/watch?v=LtqRAYWjz2Q&feature=related
    To achieve that I suppose I need to speed up the clip, but instead of using frame blending, by eliminating frames. And the problem is, that I have to eliminate more than the original frame rate (maybe the youtube I show you is 10 or 12 fps, while my shot is at 25 fs)
    So, I suppose this can be made with after effects, but I haven’t found the way.
    Can you think of any easy way, maybe by using certain expression or certain effect, to achieve this?
    Alfonso Gamez jordano replied 18 years, 8 months ago 5 Members · 5 Replies
  • Peter Van der zee
    December 21, 2007 at 12:26 pm
    Nice video.
    I would put hold keyframes in the time-remap on the frames you’re interested in and then
    pull them together like 3 to 5 frames from eachother…
    vanderzee.tv
  • Steve Roberts
    December 21, 2007 at 2:15 pm
    Search the COW for “stop motion”.
  • Bret Williams
    December 21, 2007 at 2:37 pm
    They just sped up the clip. Most likely with deinterlacing, or they simply shot it progressive. Then they apply a strobe effect (forget what it’s called in AE) or they drop it in a timeline of that frame rate. OR just render it to flash at that frame rate. For example, if the sped up look isn’t jerky enough, try a 10fps frame rate. AE will drop the frames inbetween.
  • Amit Zinman
    December 21, 2007 at 3:36 pm
    Or, you could just shoot with a stills camera
  • Alfonso Gamez jordano
    December 21, 2007 at 3:44 pm
    OK, thanks for your answers. I also found an August post with similar info.
    Finally, what I’ve found to work similarly, is importing the footage into a 8 fps comp, and then time remapping it inside.
