Activity Forums VEGAS Pro Stop motion, and DVDs on the timeline.
  • Stop motion, and DVDs on the timeline.
    Posted by Noonco on September 13, 2005 at 5:20 pm
    I had two quick questions I haven’t been able to figure out.
    I have Vegas 4 and love it with a passion.
    I’ve been told that some folks have found a way to put a DVD on the timeline.
    I’d like to be able to do this as it would save me quite some steps on encoding and reencoding a project I’m working on.
    (Note: The DVDs I’d like to put on the time line are not copyrighted, so that’s not an issue I need to work around. 🙂
    Next, does anyone know if it’s possible to set Vegas up to do stop motion animation?
    I can think of HARD ways to do it, but I was hoping there was some way I could set a camera up and capture frame by frame with a click.
    Any ideas?
    Thanks VERY much!
    Walt
    Noonco replied 21 years ago 4 Members · 11 Replies
  • 11 Replies
  • Edward Troxel
    September 13, 2005 at 8:21 pm
    Your best bet is to get them back to DV-AVI using something like DVD2AVI. If the audio is AC3, you’ll also need to convert that back to WAV.
    Edward Troxel
    JETDV Scripts
  • Noonco
    September 14, 2005 at 4:13 am
    Thanks for your reply.
    Is DVD2AVI a Vegas feature?
  • Edward Troxel
    September 14, 2005 at 1:24 pm
    No. Type it into Google.
    Edward Troxel
    JETDV Scripts
  • Adam Rose esq.
    September 14, 2005 at 4:36 pm
    someone correct me, but if you use Ultimate S2, can capture frames at set intervals, to create stop motion effect……..
    I think.
  • Edward Troxel
    September 14, 2005 at 6:02 pm
    Yes, Ultimate S 2 can capture stills at set intervals. So can Excalibur. However, in this case it sounds more like you want 1 frame each from MANY files.
    Edward Troxel
    JETDV Scripts
  • Noonco
    September 14, 2005 at 6:18 pm
    Thanks. That’s an intriguing idea!
    Walt
  • Noonco
    September 14, 2005 at 6:30 pm
    As far as the stop motion, ideally I’d like to set up a camera, and see on screen what it sees, then click somewhere to capture a single frame to the timeline.
    I’d then move my little clay figure or whatever(which the camera is recording) and click the next frame, one at a time.
    Remember Gumby?
    Thanks again!
  • Edward Troxel
    September 14, 2005 at 7:19 pm
    So, you won’t be taping the entire time. You just want the capture program to pull in one frame. Vidcap CAN capture snapshots. If numbered correctly you could then just do a File – Import, pick the first one, and check the “image sequence” box and it will bring them all to the timeline as ONE clip with each image being one frame.
    Edward Troxel
    JETDV Scripts
  • Noonco
    September 15, 2005 at 12:31 am
    Wow! This sounds like the ticket!
    Printing your reply now….
    Walt
  • Stephen Mann
    September 15, 2005 at 5:50 am
    I use Scenalyzer to do the frame-by-frame capture for timelapse then import the images as a sequence.
