Activity Forums Adobe After Effects stop motion ain AE
  • stop motion ain AE
    Posted by French Cow on May 11, 2007 at 4:32 pm
    Hi everyone,
    I’m doing a prjocet in which I’ll need to do “kind of” stop motion technic i.e: take one or two frame per second. I already shot the scenes.
    My question: is there a way in AE do to that kind of thing: ask AE to pick one frame every 10 frames ???
    Thak you all for your help
    Ghislain
    French Cow replied 19 years, 4 months ago 4 Members · 4 Replies
  • Delete
    May 11, 2007 at 8:11 pm
    Main interpretation to desired frame rate and speed adjusted to match existing footage. It’s rough, but simple.
  • Alex Brown
    May 11, 2007 at 9:42 pm
    Sounds like you might need:
    effect/time/posterize time
    Set the frame rate to 3 and you should get the look you want.
  • Joe Moya
    May 12, 2007 at 3:23 am
    … you might consider strobing the video to get the effect also… that may be easier but you may not get the same effect. Besides, if I was going to do a strobe effect… I would prefer to use dedicated editing software.
    Joe
  • French Cow
    May 15, 2007 at 8:06 pm
    Thank you all for your help…
    In fact I realised that I explained what I want the wrong way :
    What I need to do is to take one frame every 10 frames (or so) and put it in the timeline and strecht that frame for 10 frames and cross/dissolve with the next frame and so on !
    I can do that in Premiere, but I was wondering if there is a easiest way to do it in AE ?
    If you have a clue or any idea to help !!!
    Thank you all
    Ghislain
