Activity Forums Adobe After Effects Stop mask intersecting itself?
  • Stop mask intersecting itself?
    Posted by Adam Butcher on July 4, 2009 at 11:57 am
    This seems so simple that there has to be a way of doing it. I just can’t find it!
    I have a simple sillheotte mask shaped like a man’s body. If I want to animate it so that his arm moves across his body, it creates a “cut out” over his body. Why, despite all the mask options (lighten, difference etc.) can I not get it to just stay all black?
    Any help much appreciated. I’m in AE CS3.
    Tom Scott replied 17 years, 2 months ago 4 Members · 4 Replies
  • Bartek Skorupa
    July 4, 2009 at 10:19 pm
    I’d just create one mask for the body and the other one for the hand.
    Bartek Skorupa
    Warszawa, Poland
  • David Bogie
    July 6, 2009 at 2:35 pm
    Two masks will work, probably more flexible.
    But the question approaches masking incorrectly. You’re not masking out three dimensional objects when rotoscoping. You are simply drawing a line around the shape of the entire thing you are masking.
    bogiesan
  • Adam Butcher
    July 6, 2009 at 3:52 pm
    Thanks, but I figured 2 seperate masks would be suggested. It’s just still seems more complicated than necassary. And it’s certainly a *less* flexible solution.
    To clarify, I’m not rotoscoping:
    It’s just a simple figure. If I wanted his arm to turn into a tentacle and go across him, is there no easier way to get it not to go all “checkerpattern”? This may seem a little stupid, but what if I wanted to make a silheotte octupus?
  • Tom Scott
    July 7, 2009 at 2:13 am
    Pre-compose, then use the puppet tool to animate your figure.
    DISCLAIMER: The contents of this post are based primarily on the opinions/understanding of the author. However, commonly known facts may also be included, when relevant.
