Activity Forums Adobe After Effects Expressions stop keyframes from animating using an expression?
  • stop keyframes from animating using an expression?
    Posted by Carlos Bautista on May 7, 2014 at 9:09 am
    hi guys,
    just wanted to ask, if there’s an expression to stop keyframes from animating using an expression?
    e.g. if there are 2 keyframes for the position property,
    then if i put that that certain expression, it wiLL not proceed
    to animate
    is there such an expression?
    whats the use for me? why not just deLete the keyframes right?
    but i dont want to deLete the keyframes, i wouLd Like to have an option to on/off it as i want to, if ever i change my mind to put the animation back again..
    Carlos Bautista replied 12 years, 4 months ago 3 Members · 3 Replies
  • Todd Kopriva
    May 7, 2014 at 2:29 pm
    You can just have an extremely simple expression that sets the value of the property to a constant.
    After Effects team blog
  • Dan Ebberts
    May 7, 2014 at 4:21 pm
    Something like this should hold the value occuring at the layer’s in point:
    valueAtTime(inPoint)
    Dan
  • Carlos Bautista
    May 9, 2014 at 8:49 am
    this works.. 🙂
    super thankx dan!
