Activity Forums DVD Authoring Stop at End of Chapter
  • Stop at End of Chapter
    Posted by Abbie Labadie on April 20, 2010 at 10:50 pm
    This shouldn’t be that difficult – I’m trying to create a DVD demonstrating the winemaking process; the educator needs to have the video stop at the end of each particular part of the process. I have end action set to Stop for each chapter. It needs to hold on the last frame of that chapter, so the educator can pause for Q&A, then either play that chapter again, continue to the next chapter, or go to the main menu – but it goes to black. I can’t get it to work right (of course, it does in the preview) – is there a way of doing this in DVD Studio Pro or Encore? I’ve tried both. Or is this too complex for those programs? (Or for me, ha ha)
    I was hoping it would work in Encore, because we need to eventually make the same thing in HD on BluRay.
    Thanks for any input. I’ve searched & searched & tried different things to no avail…
    Rob Neidig replied 16 years, 5 months ago 3 Members · 3 Replies
  • Michael Sacci
    April 20, 2010 at 11:47 pm
    It is not hard but you have to understand what is going on.
    The Pause command works on the next chapter marker. So if you want to pause the playback at chapter 2 you put the pause command on chapter one, then the screen you want to hold on should be the first frame of chapter 2. Remember a chapter mark has to fall on an I-frame so you need to use a sec of that frame. Then simply using the remote you can hit play, prev chapter or menu button.
  • Abbie Labadie
    April 21, 2010 at 7:31 am
    Thanks, Michael! I will try that tomorrow.
  • Rob Neidig
    April 21, 2010 at 3:18 pm
    The other way to do it would be to create a menu page that the player would go to at the end of the chapter. It would happily sit there until you make a menu choice, such as “Replay Chapter”, “Go to Main Menu”, etc.
    Rob Neidig
    R&R Media Productions
    Eugene, Oregon
