Activity Forums Adobe After Effects Expressions Stop and go (traffic jam, clock hands )
  • Stop and go (traffic jam, clock hands )
    Posted by Roger Maus on July 13, 2012 at 1:17 am
    i am searching for an expression that makes a value “stop and go” between given keyframes.
    It’s like in a traffic jam (or the hands of a clock): hold the value for some time, then catch up to make up the leeway. (The graph would look like stairs with inclined gain.)
    There are a lot examples around in which the value *jump* to the next value, but theres no examples with a linear developement, not to mention *eased* change.
    Any hints?
    Roger Maus replied 14 years, 2 months ago 2 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    July 13, 2012 at 2:14 am
    That would probably be something like this:
    pct = .7;
    if (numKeys > 1 && time >= key(1).time && time <= key(numKeys).time){
    n = nearestKey(time).index;
    if (key(n).time > time) n--;
    t1 = key(n).time;
    t2 = key(n+1).time;
    v1 = key(n).value;
    v2 = key(n+1).value;
    t = time - t1;
    ease(t,pct*(t2-t1),t2-t1,v1,v2);
    }else
    value
    Set pct to the fraction of the time between keyframes that you want to hold the value of the first keyframe.
    Dan
  • Roger Maus
    July 13, 2012 at 2:42 am
    Apart from the error that after effects gives me with this expression (something about “no such thing as a subsequent key”) I’m afraid I couldn’t make myself clear.
    If I get it right, this expression makes the value wait at every key. But what I want is to give only the start and the end, and all the stop’n’goes inbetween beeing calculated:
    Only the key at the beginning and at the end is given, and so is t1 and t2.
    (PS. the last stopping/recovery is depicted mistakingly. there’s half a “cycle” too much.)
  • Dan Ebberts
    July 13, 2012 at 3:19 am
    This should be closer:
    t1 = 1;
    t2 = 1;
    if (numKeys > 1 && time > key(1).time && time < key(2).time){
    span = key(2).time - key(1).time;
    steps = Math.floor(span/(t1+t2));
    valPerStep = (key(2).value - key(1).value)/steps;
    curStep = Math.floor((time-key(1).time)/(t1+t2))
    t = (time - key(1).time)%(t1+t2);
    v1 = curStep*valPerStep;
    ease(t,t1,t1+t2,v1,v1+valPerStep)
    }else
    value
    Dan
  • Roger Maus
    July 13, 2012 at 3:51 am
    Almost perfect… it does what it should, but at the wrong position!
    The object jumps to [0,0] to perform its jaggy movement, and in the end it jumps at its keyed postition…
  • Dan Ebberts
    July 13, 2012 at 4:56 am
    Ah, yes. Try it this way:
    t1 = 1;
    t2 = 1;
    curStep = Math.floor((time-key(1).time)/(t1+t2));
    if (curStep < steps){
    v1 = key(1).value + curStep*valPerStep;
    ease(t,t1,t1+t2,v1,v1+valPerStep);
    }else{
    key(2).value;
    }else
    value
    Dan
  • Roger Maus
    July 13, 2012 at 1:40 pm
    Thanks for all the effort, Dan…. I am sorry for beeing so helpless, and I feel kind of cheeky and picky…
    but the problem pesists…
    the erroneus expression in action. (different t1/t2 for the characters)
    https://reels.creativecow.net/film/16812
    and there’s a strange jump, too.
  • Dan Ebberts
    July 13, 2012 at 5:30 pm
    I’m not sure what’s going on. Do you have more than two keyframes? I did find a strange glitch where JavaScript’s modulo operator (%) gives incorrect results in some cases. That causes the jump you’re seeing. This version should correct that problem:
    t1 = .5;
    t2 = .3;
    t = (time-key(1).time)/(t1+t2) - curStep;
    }else{
    key(2).value;
    }else
    value
    Dan
  • Roger Maus
    July 17, 2012 at 7:03 am
    works flawlessly! thank you so much!
