Activity › Forums › VEGAS Pro › Stitching videos with no compression
  • Stitching videos with no compression
    Posted by Johnny Allen on July 9, 2012 at 7:52 am
    I’m hoping you folks can help me with a problem that has vexed me off and on for over a year. I apologize for the lengthy post but I wanted to be clear with what I was aiming for.
    Here is what I’m trying to do: I record PC game footage @ 1920×1200 using an application called FRAPS. It uses a near-lossless codec. The recorded video is broken up into ~4 gig files.
    What I do currently is to have Fraps encode all my day’s recordings overnight (h264.) The next day, I use VDub to splice the encoded files together into ~30 minute segments.
    What I want to do is use Sony Vegas 11 to add an external audio file (commentary) and do minor editing. I’d then like to save these movie files uncompressed and encode them via Virtual Dub using h264. I then upload these videos to YouTube for my fellow nerds to watch.
    The problem is that I cannot figure out how to save the video uncompressed in Vegas. In VDub, all I would need to do would be to set both Video and Audio to “Direct Stream Copy” and save as an AVI. I’ve read tons of various suggestions and everything I’ve tried in Vegas either ends up with a huge file (3-4 gigs for 1 minute) or unacceptably low quality.
    The end goal is have the closest to source video quality possible with a reasonable file size. Encoding time isn’t a major concern as, ideally, I could do all my editing in one go and then set VDub to encode all of them overnight.
    Any suggestions? Or am I going about this all wrong?
    Johnny Allen replied 14 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeff Schroeder
    July 9, 2012 at 12:43 pm
    I would skip the uncompressed-virtual dub step and just render to mp4 (h264) from within Vegas. Try the Sony AVC templates.
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Johnny Allen
    July 11, 2012 at 12:39 am
    Hi Jeff,
    Thank you for the feedback. I did some tweaking and am using the AVC with some custom settings. This seems to work pretty well. The only thing I’m not crazy about is that it cannot output a 1920×1200 video. Since I record at that resolution, that is what I’d prefer to output to. Is this a universal limitation, or just something Sony does with Vegas?
    Thanks again for your help!
  • Jeff Schroeder
    July 11, 2012 at 2:56 am
    [Johnny Allen] “it cannot output a 1920×1200 video”
    News to me… Are you using Sony AVC? Change the size in the Boxes. You should be able to set a custom size.
    Jeff
  • Johnny Allen
    July 11, 2012 at 2:27 pm
    When I try to do that, it gave me an error. I’m not at home right now so not sure what the exact wordage is, but it basically said that Vegas could not output to a resolution higher than (I think) 1920×1080. I have the trial of Vegas Movie Studio HD Platinum 11.
  • Jeff Schroeder
    July 11, 2012 at 3:23 pm
    The Main Concept AVC will allow you to do this. (At least in Vegas 11 Pro)
    I don’t work much with this one.
    Jeff
  • Matt Crowley
    July 11, 2012 at 6:50 pm
    Movie Studio HD does not allow projects or renders larger than 1920×1080 so you are stuck if you need 1920×1200 (16:10 instead of 16:9). However, it will allow you to import video and stills larger than 1920×1080. Vegas Pro allows larger frame sizes but they are normally only used for cinematic post-production.
    1920×1200 is not a standard HD format anyway (it would probably get pillarboxed on TV or youtube/vimeo/etc playback), so you might be better off either cropping the footage (unless that chops off your game’s status/OSD panels) or setting your game resolution to 1920×1080 and aspect ratio to 16:9 instead of 1920×1200 and 16:10.
  • Johnny Allen
    July 11, 2012 at 11:34 pm
    Thanks for the information/advice. I may just start playing in 1920×1080.
    Thank you both for the help!
