Activity Forums Maxon Cinema 4D Stitching and Deformation
  • Stitching and Deformation
    Posted by Seth Olson on April 16, 2014 at 5:02 pm
    I want to have stitches (cloned geometry) pinch the fabric. I was thinking: use an ambient occlusion shader on the displacement channel. but I can’t seem to get it to work. It only uses the color from the end of the spectrum of the ambient occlusion gradient. Any ideas?
    Seth Olson replied 12 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 16, 2014 at 7:00 pm
    You probably need to adjust the Min/Max ray length settings in the AO shader.
  • Seth Olson
    April 21, 2014 at 7:56 pm
    I messed around with it, but couldn’t get the results I wanted. I’m going to just “make editable” and push some high resolution ploys around. Thanks though!
