Activity Forums VEGAS Pro Stills squeezed on render playback
  • Stills squeezed on render playback
    Posted by Thayer Radic on March 2, 2009 at 6:23 pm
    Hello,
    Ive been rendering out an HDV avi video with some stills incorporated. When I render the video the stills become squeezed and therefore do not retain their aspect ratio as on the timeline.
    but….this only shows when viewing with WMP or FLV. When I view the clip in my NERO player the pictures look as they should are are not squeezed.
    Is this just a matter of playback apps or an issue with how I rendered a video that contains stills?
    Thanks.
    John Rofrano replied 17 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    March 2, 2009 at 7:32 pm
    You may have rendered using a template that does not use square pixels and some playback applications are smart enough to know this and some are not. If your target device is a PC/web then use a template that has a pixel aspect of 1.0. If your target device is a TV then don’t worry about it. TV’s understand pixel aspect and will play them correctly.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
