Activity Forums Apple Final Cut Pro Legacy stills shake in final cut
  • stills shake in final cut
    Posted by Fuabond on April 13, 2006 at 11:10 pm
    Hi everyone,
    Can someone please help me, I have a slide show in final cut in one of my videos, but the stills are shaking a bit, can any body tell me why??
    thanx
    Fuabond replied 20 years, 5 months ago 3 Members · 3 Replies
  • Saya Hillman
    April 13, 2006 at 11:16 pm
    You probably have to put filters on each one — go to Video Filters, Video, and choose De-Interlace. Once you drop that in a stilll, change the Flicker Field to max in the Viewer.
    If you do it on one still, you can copy and paste attributes for the rest.
  • Thaxter Clavemarlton
    April 14, 2006 at 2:49 am
    What kind of “stills”?
    Are they imported images or video freeze-frames?
    If they are imported images, you might need to “soften” the image for video by adding the “gaussian blur” filter set to a low (0.25- 1.0) amount.
    If they are freeze-frames grabbed from moving video, as suggested, you should add the “de-interlace” filter (or the “flicker filter”).
  • Fuabond
    April 14, 2006 at 8:37 am
    Guys thanks a lot, I put the filter and like magic it looks perfect, thanks a lot.
    Felipe
