Activity › Forums › Adobe After Effects › Still shot to video
Still shot to video
Posted by Russ930 on December 2, 2007 at 9:36 pmI am trying to created an effect where a still shot starts playing.
I have the still shot looking like a Polaroid but have to been able
to get a smooth transition to video. Any advice
ThanksFrank Hardie replied 18 years, 9 months ago 4 Members · 7 Replies -
Steve Roberts
December 2, 2007 at 10:29 pmConsider applying time remapping (or Timewarp) to the video so it speeds up from 0 to normal. Details are in the Help.
There will be some jerkiness at the beginning, probably. To avoid that, consider buying the Twixtor plugin.
Russ930
December 2, 2007 at 11:41 pmThe actual effect is that a photo gets tossed onto a table and than comes to life. The photo is a still taken from the video. My problem is having a smooth transition from a still to a movie. I realize that the Polaroid effect makes this more difficult since the ratio of the photo is different from the video.
Steve Roberts
December 3, 2007 at 12:16 amDo you want the video in the Polaroid to play full frame, filling the screen? If so, you’ll need to show the still flying toward camera, where it settles and starts playing, no? If that’s the plan, I’d show the full height of the video in the Polaroid, but mask off the sides. When it flies toward camera, I’d fade up the sides that were cut off.
Or you could squeeze the video into the Polaroid and see if anybody notices. Then you’d stretch it out to normal dimensions as you fly it toward camera…?
Frank Hardie
December 3, 2007 at 1:58 am[Steve Roberts] “I’d show the full height of the video in the Polaroid, but mask off the sides. When it flies toward camera, I’d fade up the sides that were cut off.”
Or maybe, animate the masks (on the sides) to reveal the full width of the video.
Frank Hardie
December 3, 2007 at 2:06 amPersonally, I’d try both the fade and the mask animation, then decide which I’d prefer. Depending on the look you’re after, one may be more suitable than the other.
