Activity Forums Apple Final Cut Pro Legacy still rendering problems
  • still rendering problems
    Posted by Vasja Mihelcic on December 22, 2010 at 4:48 pm
    ,ve got some mp4 files for editing.1. I changed the extension to mov. and star to work. When putt on time line i need to render it. 2. I used the compressor to change it in to prores 422 but still rendering.
    3. If i use directly the file mp4 on a time line it is rendering.
    What do i have to do in settings that it does not render all the time i do move my clip?
    when i use tape to capture or loggin no problem.
    GOT MP4 file and when editing it renders all the time.
    thx vasja
    our sequence settings have to match your video settings for it not to render.
    The easiest way to do this (and if you are using the latest version of FCP) Make a new sequence and open it. Drag your Pro Res footage into the timeline, it will ask you if you want to change your sequence settings to match your footage. Say YES.
    If this doesn’t work, let us know.
    C.R.
    O.k i did that…The video did not have too be rendered but the sound i had to render…
    My proces:
    mp4 file in the compressor converted in to apple prores 422.
    Proces:
    i apply the settings and drag it to the source video. It was made in 10 – 20 sec. for 4 min. material.
    The file was imported to the final cut pro as a new project.
    When i putt it on the time line i was asked to match the settings of the sequence i confirmed yes.
    VIdeo was o.k avdio had to be rendered.
    Is there a mistake in converting the file in compressor?
    my system settings a/v:
    sequence present: apple prores 422 pal 48 khz
    Kai Cheong replied 15 years, 9 months ago 3 Members · 2 Replies
  • Christina Rodriguez
    December 24, 2010 at 2:41 am
    Can you upload a snap shot of your clip settings AND of your sequence settings? (shift-command-4) a file will appear on your desk top.
    C.R.
  • Kai Cheong
    December 28, 2010 at 3:08 pm
    If it’s sound giving you problems, it might be because the audio wasn’t transcoded when you sent the file through Compressor.
    Load the original .mp4 into Compressor, apply the ProRes setting, go to the 2nd tab in the Inspector window. The default seems to be that ‘Audio’ is ‘Pass-through’. Change it to ‘Enable’ and adjust it to be 48kHz.
    Kai
    FCP Editor / Producer with Intuitive Films
    https://kai-fcp-editor.blogspot.com
    Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
    At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
    Visit us @ https://www.intuitivefilms.com
    MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.7
    8-Core Intel Mac Pro 2.26GHz | 8GB RAM | FCP 6.0.6 | Mac OS X 10.5.6 | 3.0TB CalDigit VR | 2 x 24″ Dell S2409W
