Activity Forums Adobe Photoshop still pixelated at 300 dpi
  • still pixelated at 300 dpi
    Posted by Judy Singh on November 5, 2008 at 4:26 pm
    I’m using PS CS2 to create a small web ad from a supplied logo, a stock 72 dpi background and text.
    The logo is a newer eps file so it won’t open in my Illustrator version which I normally would use to create a vector to import into PS but since this is not working i just imported it into PS thinking that since I was scaling DOWN from 2300 to 200 px it wouldn’t pixelate — but it is.
    The test is pixelated too but I’ve tried every anti-aliasing setting and no matter what I do it still comes out terrible.
    Is there something else I’m missing???
    I’ve made lots of things in PS before and never had this sort of problem. There must be a logical solution…???
    –apparently PS is not the place for txt but I know I’ve done it many times before successfully…
    Power Mac G5 Quad 2.5 Ghz (11.2)
    2.5G RAM
    OS X 10.4.11
    FCP 5.0.4
    Compressor 2.0.1
    DVDSP 4.0.3
    — experience is tough teacher
    she gives the test first
    and the lesson afterwards
    Jeff Kelley replied 17 years, 10 months ago 2 Members · 1 Reply
  • Jeff Kelley
    November 7, 2008 at 3:47 pm
    Is it pixelated on the screen or have you done a print test? I usually work at 300 ppi, but 200 should be passable. You might check the size of you doc. If you are printing at 200 ppi and you image needs to be printed at 200%, your really only working in 100 ppi
    Make sure you looking at you image at 100% on screen to get a good idea of what it looks like.
    http://www.willinois.com
