Activity › Forums › Adobe Premiere Pro › Still no TC?
  • Still no TC?
    Posted by Kurome on January 18, 2006 at 1:37 pm
    As Premiere flashes with the opportunity to work with high resolution pictures and film scans, the audio functionality still seems to be left lacking.
    Major problem on our workflow is that we usually take audio and video from separate sources with synced timecode (DAT and camera, that is). Surely programming a button to sync this material would not be a trick. But no. Allthough I begged for it 🙁
    Please, correct me, ‘cos hopefully i’m wrong!
    Kurome replied 20 years, 8 months ago 3 Members · 4 Replies
  • Steve Freebairn
    January 18, 2006 at 3:13 pm
    can’t you sync it through the multicam feature?
  • Eric Jurgenson
    January 18, 2006 at 5:54 pm
    How about:
    Load Clip #1 in source viewer. Select appropriate cue point and set marker.
    Right click on source TC# and copy.
    Place Clip #1 on timeline.
    Load Clip #2 with synched TC in source viewer. Paste previous TC# into source TC# box.
    Set marker and drop into timeline (different track). Line up markers.
    This is pretty quick. The markers will stay with the clips, which could be handy if things get out of sync later.
  • Eric Jurgenson
    January 18, 2006 at 10:19 pm
    I think there is a TC match button in 2.0 for multicam that should work for this application as well.
  • Kurome
    January 20, 2006 at 10:35 am
    Woohoo.
    That helps a lot. Hopefully the AAF will work on pro tools *crosses fingers*
