Activity › Forums › Apple Final Cut Pro › Still issues relinking XML?
  • Still issues relinking XML?
    Posted by Bret Williams on October 31, 2014 at 5:20 am
    Maybe I’ll run this through resolve. But a client just sent me a premiere project, an edl, and an XML. We both have the same ProRes 422 media. So, I import the simple cuts sequence via 7toX from his XML. A few of the clips relink, but the rest refuse, stating there isn’t a common range. They have the same file name, same specs (1080p 23.98), same duration, same start TC and same end TC. I don’t know anything else that could be any more exactly the same. Except for the fact that they are the same files.
    His files have gone through premiere. That’s all I can figure. But I have 1300 other files that XML’d from Premiere the same way and they all relink sans one.
    In fact, I already had the media in my library, so when the XML came in, it should have seen the media was available. But nope. Here’s a screenshot of the two files lined up in the browser-
    Sometimes I just want to know what the hell is wrong with this frickin’ app.
    Bret Williams replied 11 years, 10 months ago 2 Members · 5 Replies
  • Bret Williams
    October 31, 2014 at 6:19 am
    UPDATE: same XML opens and relinks in Resolve Lite 11.1.1 without a hitch. So, then export XML from resolve and open in FCP X and the same clips won’t relink.
  • Jeremy Garchow
    October 31, 2014 at 11:38 am
    My guess is XMP.
    For whatever reason, it wreaks havoc on X.
    I would contact Apple via the feedback page. Offer to provide a library and media.
    QT Edit can remove XMP.
  • Bret Williams
    October 31, 2014 at 12:30 pm
    QT edit isn’t free is it? I have it but it says my trial is over.
  • Jeremy Garchow
    October 31, 2014 at 12:43 pm
    It is not free. How big is the offending file? Is it uploadable?
    You can hit me up offline too if you need.
  • Bret Williams
    October 31, 2014 at 12:48 pm
    I appreciate it but it’s probably a half hour or more of pro res. it all opens fine in resolve so I can pull selects from there and write down (OMG!) the TCs.
    I think the first round must have been done with premiere with write XMP ID turned off.
