Activity Forums Adobe Premiere Pro still images
  • still images
    Posted by Jeff Scool on September 21, 2007 at 10:21 pm
    Hi:
    Quick question-and hopefully, easy answer–just wondering if anyone knows of a way to eliminate a still image shake during playback…I have a movie with a couple “meaningful” stills and in Premiere, all looks great, but when I export to DVD and playback movie, when the stills appear, they shake, losing all meaningfull-ness and just looking absurd…Any thoughts?
    JHST
    Jeff Scool replied 18 years, 11 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    September 21, 2007 at 11:30 pm
    A couple of things:
    1) If you are using PPRO CS3, increase the anti-flicker value of the motion filter.
    2) If your image size is too big, reduce it a little bit.
    – Aanarav
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Ditha Angraini
    September 22, 2007 at 7:26 am
    I normally apply flicker removal and it worked, you can find it by right clicking on the footage/clip in your timieline, choose field option, and select flicker removal.
  • Jeff Scool
    September 22, 2007 at 12:48 pm
    thanks to you both for the reply…i’ll try both and see what happens…
