Activity › Forums › Apple Final Cut Pro Legacy › Still Images Wont Render in Final Cut
  • Still Images Wont Render in Final Cut
    Posted by Rob Davis on November 8, 2008 at 12:05 am
    I’m having a problem.
    I have a sequence of still images and audio.
    Here are the sequence settings: https://www.robdavisphotography.com/settings.jpg
    When I playback after rendering the images only appear on the canvas during the first part of their duration on the timeline. i.e. If the image is on the timline for a duration of 5 seconds, the image will playback for the first 1 second and then playback for the next 4 seconds.
    When I export all the images playback very quickly in the begining of the clip and then it is all black for the the rest. i.e. If I have `10 images set to play 5 seconds each for a total duration of 50 seconds, all the images play in the first 10 seconds and then the last 40 seconds are black.
    Any suggestions for why this might be happening.
    Chris Borjis replied 17 years, 10 months ago 2 Members · 1 Reply
  • Chris Borjis
    November 8, 2008 at 1:07 am
    change the compressor type From HDV to ProRes.
