Activity Forums Apple Final Cut Pro Legacy Still Images in FCP5 issues
  • Still Images in FCP5 issues
    Posted by Mrclean796 on August 17, 2005 at 2:57 pm
    Having a problem with still images in FCP 5. When I import a still image, and then animate it (Either with a drop shadow, scaling, rotation, ETC, ) The image looks kind of crappy and the image will get kind of “jumpy” . For example, if I take a 720 x 486 pic, scale it down and have it scale up over a certain period of time with both a scaling and position keyframing, it jjumps p and grows, jumps up and grows . . . Now, my suestion is, do I have some sort of settings set wrong? Am I importing the wrong kind of still with the wrong settings? (square pixels vs. 0.9)? Any advice/guidannce is greatly appreciated.
    Mrclean796 replied 21 years, 1 month ago 4 Members · 5 Replies
  • Thaxter Clavemarlton
    August 17, 2005 at 3:08 pm
    Are you RENDERING this effect (you need to).
    Are you checking for quality only on an EXTERNAL video monitor?
  • Mrclean796
    August 17, 2005 at 4:46 pm
    I did indeed rener the animation out, not so sure what you mean about the external monitor bit. I have dual display monitors, and a Sony HRTrinitron for my external monitor, and it looks kind of crappy on both. Also, when put off to tape, it looks kind of crappy too. I am going from the FCP to an AJA Breakout box, is there some sort of issue here?
  • Mark Maness
    August 17, 2005 at 7:00 pm
    Check your render settings. I would have to bet that you sequence is set to “Normal”. Try setting it to “Best” or “Fastest”. The motion quality of FCP is lacking very seriously. It was supposed to be better but I think its gotten worse. I constantly have problems with alpha channel logos. Its a flip of the coin to what the settings are.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Dave Jenkins
    August 17, 2005 at 8:28 pm
    Yes, I have had the same results a Wayne. Most of the time we find (Fastest) works best. I hope Apple fixes this soooon.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Mrclean796
    August 18, 2005 at 7:19 pm
    YES! In the Sequence>Settings>Video Processing Tab there I set it to best and it looks SOOOO much better. YOU GUYS ROCK!
