Activity Forums Avid Media Composer Still images appearing aliased with jagged edges on DVDs
  • Still images appearing aliased with jagged edges on DVDs
    Posted by Victor Seckeler on December 22, 2013 at 3:49 am
    For years I have built programs that included still images that I added to the shows using Moving Pictures. On DVDs these images appeared as very high quality. All of a sudden, the images on DVDs appear to be aliased with jagged edges. I have not found a way to stop the aliasing.
    I tried three different DVD encoder/burners, so I don’t think it’s that — I tried Avid DVD, Sorenson Squeeze, and outputting directly to a Pioneer PRV-LX1. They all have the same problem.
    I tried Avid Pan & Zoom as well as the 64-bit version of Moving Pictures, so I don’t think it’s there.
    It’s as if the still images are only showing one field, though they are interlaced pictures in an NTSC 30i 4:3 Standard Def program. Any ideas would be most appreciated.
    My system is a Windows 7 – Media Composer 7.02 with Symphony option on an HP Z820. My video card is a Kona 3g.
    Thank you.
    Victor Seckeler
    John Pale replied 12 years, 8 months ago 4 Members · 4 Replies
  • Victor Seckeler
    December 22, 2013 at 2:39 pm
    UPDATE – still images work perfectly in a hi def project, so I am guessing this is a bug in how 7.02 is working with SD files, or a mistake in my workflow. Also, when I expand the pics in the timeline they immediately show aliasing in the SD project. The HD project’s stills blowup cleanly.
    Victor Seckeler
  • David Hammer
    December 22, 2013 at 6:20 pm
    I just installed v7.0.2 (moving from v6) and am seeing the same trouble with rendered stills. FrameFlex looks better than Pan & Zoom but is still unusable. I don’t have Stage Tools on this system to check.
    My projects are NTSC using Avid 1:1 10bit. I have checked Import settings, Render settings to make sure everything is correct there. I am monitoring through an AJA Kona LHi feeding an SD broadcast monitor.
    EDIT: I am on a Mac running 10.8.5. All my Kona software is up to date
    Anyone else seeing this?
    David Hammer
    Brightwood Studios
    david@brightwoodstudios.com
  • Michael Mccune
    December 26, 2013 at 2:08 am
    … just a thought …
    We all hope you find some simple setting or fix. BUT …
    Is it supposed to work with MC 7.02?
    Probably once a welcome tool, but is it actively updated?
    StageTools 64-bit capability was introduced about January 2012, during the reign of MC 6.
    Unless I am missing a lot, the StageTools site does not seem to have a version history, revision history nor release notes.
    There seems to be no contact info on their site other than info@stagetools.com.
    And MC 7.02 Release Notes make specific mention of field-based effects editing changes.
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDwQFjAA&url=http%3A%2F%2Fresources.avid.com%2FSupportFiles%2Fattach%2FMC702RN.pdf&ei=voa7UvDvJoPwoATo3oGYBw&usg=AFQjCNFsCD6HezTv9zawVMLC8zYA2xIcag&bvm=bv.58187178,d.cGU
    Is that a clue?
    Yours,
    Mike McCune
  • John Pale
    December 27, 2013 at 5:04 pm
    Ummmm…..
    That Read Me is from the original Avid v 7.02 released in 1998.
    Avid restarted the version numbers sometime around the release of the Avid Adrenaline.
    Cool seeing the old pre-OSX Mac interface, though.
