  • Posted by Tim Hore on September 28, 2009 at 9:21 am
    I want to add a still image taken directly from a moving shot and add this back to the timeline. At the moment I get the comb effect on the frozen image when I view it.
    I have tried exporting both a still image via quicktime conversion as well as making a freeze frame direct from the sequence. Both have the same effect. Looks like an interlace issue.
    What is the best export setting for the still image to deliver a clean still?
    Tympani Productions
    Rafael Amador replied 16 years, 12 months ago 2 Members · 1 Reply
  • Rafael Amador
    September 28, 2009 at 11:39 am
    Hi Tom,
    If you are working with interlaced footage, sure you are getting the two fields in your freeze Frame.
    Just drop a de-interlacer filter before making the Freeze frame.
    Best,
    rafael
    http://www.nagavideo.com
