Activity Forums Avid Media Composer Still having problems
  • Still having problems
    Posted by Diego Villalba on September 22, 2005 at 8:20 pm
    As I put in a post before I sitill having problems when I try to create DVD’s.
    I give up, trying to use the create DVD an the export as m2v functions, so now I’m exporting as Uncompressed AVI (because I use Encore DVD), and guess what!… another problem!!! Is it possible to create AVI’s bigger than 2GB? Please tell me why!!!
    Thanks a lot…
    diego
    PS: below you will se my post before… Bye and thanks again…
    Note: To include any portion of this post in your response, highlight the desired text with your mouse and hit the “Q” key.
    Date: Sep 15, 2005 at 3:42:18 pm
    Subject: Xpress DV export problem
    Hi there!
    I’m having problems when I try to use the “Create DVD” or export to “mpeg 2” functions… I received the following error messege…
    “AS_EncodeQTVideo() returned -1.”
    Does anybody Knows what I’m doing wrong?
    Thanks a lot!!!
    diego
    Jon Zanone replied 20 years, 12 months ago 2 Members · 3 Replies
  • Jon Zanone
    September 25, 2005 at 1:30 pm
    The 2GB limit is an OS problem – not an Avid problem.
    Export your video as either a QT reference or a QT same as source, and compress it with a 2d party application with something like like Sorenson, Procoder, or Cleaner.
    I never had luck with Avid’s export option, and I’m pretty sure that’s why the option disapeared in later versions. If you buy a new Avid, Soreneson comes bundled with it.
    Jon
  • Diego Villalba
    September 26, 2005 at 12:39 pm
    Thanks Jon
    But if the problem is the OS, why can I export AVIs bigger than 2Gb with Premiere Pro? (I have Win XP Professional SP1).
    About the export as a QT Reference… I can’t too…
    I think all the problem with the export has to be with QT… Because the only format that I can export is .AVI files. I tried with QT 5 and 7 and the problem is still there.
    Could be an incompatiblity with my video card or with my motherboard?
    diego
  • Jon Zanone
    September 26, 2005 at 5:40 pm
    I guess the first question I should have asked was what is your system? Avid is notorius for over promising and under delivering in the mpeg department, IMHO. The best success I’ve had is exporting a QT and compressing it with a 2d party program (Sorenson / Procoder / Cleaner). As long as you are running an Avid-approved system, there should be no conflicts.
    Jon
