Activity Forums Media 100 Still having import probs…
  • Still having import probs…
    Posted by Paul Crowe on March 15, 2011 at 10:09 pm
    Hi again, so I managed to find a good link to download the latest Sony transfer s/w (thanks Murray).
    And again, the Transfer s/w goes through the motions. Then when M100 does it’s bit the blue progress line gets to near the end and M100 crashes – arrghh!
    Error codes as follows: “Could not import the file ex3(blah blah).mov because the program error type -2014 occurred. Followed by another error message -19308
    Then the full M100 crash warning comes up telling me to write down the parameters which I didn’t. But I will when it happens again.
    Running OSX 10.6.6, M100 suite 1.7, Sony XDCam transfer v2.12.0
    Any ideas as to what might be going on here, and how I may be able to fix it?
    Cheers
    Paul
    Paul Crowe replied 15 years, 6 months ago 3 Members · 4 Replies
  • Dave Mccarthy
    March 15, 2011 at 11:56 pm
    Do you have the XDCAM codecs installed? (XDCAM Transfer will warn you about that when it starts, I think.)
    Have you set your Media Destinations correctly? Do you have read/write permissions to those locations?
    What standard were the clips shot in? (frame size, frame rate, codec)
  • Paul Crowe
    March 16, 2011 at 12:31 am
    I love this forum. Simple! Thanks Dave problem solved.
    There has been a missing driver warning showing up in the XDCAM transfer opening for a little while but I’ve ignored it up until now because everything was actually working fine. But with a recent OSX upgrade this changed – so by simply installing that it works! Doh!
    Cheers
    Paul
  • Jim Wiseman
    March 18, 2011 at 4:38 am
    Which driver was missing?
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Final Cut Studio 2 and 3, Media 100 Suite 1.6.1, AJA ioHD, AJA Kona LHi Avid MC, Hexacore MacPro 3.33 Ghz, Macbook Pro Core2Duo, G5 Quadcore PCIe, Media 100i/XR
  • Paul Crowe
    March 20, 2011 at 10:59 pm
    Damn, sorry Jim I can’t remember…
    It was the very last driver on the list that comes up when you have a missing driver error message via the XDCAM transfer s/w. But of course now that I no longer have an error warning that comes up I cant check to see which one it was.
    Cheers
    Paul
