Activity Forums Blackmagic Design STILL HAVING EXTREME Problems with Firewire editing in systems
  • STILL HAVING EXTREME Problems with Firewire editing in systems
    Posted by Dane Silzle on May 28, 2005 at 4:55 pm
    Need help extremely frustrated !!!
    I have been editing in FCP 3 and 4 and will be installing FCP 5 soon.
    I do most of my work in SD 4.2.2 with My Deckllink Extreme card on my G5.
    I have no problem with 10bit uncompressed even up to 1 hout long sequences
    working with the Decklink card and my HUGE U320 RAID, 3 video tracks, 6 or more AUDIO, Live type and everything works smoth as silk, (monitoring,editing, you name it).
    However because of storage space I still want to edit some event work in DV.
    This involves some sequences 15minutes or longer. When I work in DV within
    the first minute both the displays (in FCP and my NTSC monitor) start getting
    jerky, drop frame warning comes up ….
    I have looked on other threads on this forum and have tryed; trashing FCP prefrences (from user>Library) and have checked my Viewers and set them to Fitall
    Also thinking I might have a conflick with my Decklink card and apples firewire
    I switch back to my dual G4 for firewire but still have the same problems.
    I also have a new 1.67ghz power book that does it too, although a little less.
    I must be doin somthing worng cause
    On all of my systems I run RAID’s:
    do I have to install another FW card to make these systems work wright ?
    here is my systems:
    SYSTEM 1
    Dual 2ghz G5
    10.3.8
    2.5gb DDR
    FCP 4.6
    HUGE U320 RAID 1.2TB (ave. 320mbs)
    decklink extreme capture card
    SYSTEM 2
    Dual 1.42ghz G4
    10.3.8
    FCP 4.6
    2.5gb DDR
    SIIG internal RAID 320GB
    SYSTEM 3
    1.67ghz 15″ Power Book
    1gb DDR
    FCP 4.6
    External G-RAID 320GB (FW 800)
    plus PCMCIA FW 400 card for capture.
    Note this system edits DV best ??? go figure
    please offer HELP
    Dane
    Mathias Hekton replied 21 years, 2 months ago 2 Members · 1 Reply
  • Mathias Hekton
    June 4, 2005 at 11:53 am
    Capture your DV footage to your internal harddrive. I know it sound stupid but I had major problems trying to capture and playback DV from my SCSI Raid. Used the internal drive instead and it just flies. Good luck!
    /mathias
