Activity › Forums › DaVinci Resolve › Still haven’t solved my 60fps to 24fps workflow problem
  • Still haven’t solved my 60fps to 24fps workflow problem
    Posted by Jan Von bayern on March 28, 2015 at 10:44 pm
    Hello everybody,
    I shot Cinema DNG raw files with my Odyssey 7Q in 60fps.
    What I want to do:
    – bring into DaVinci,
    -slow it down to 24fps
    -give it a basic grade
    -export it for a FCPX edit
    -roundtrip it back into DaVinci for the final grade
    I can right click the clip in the timeline and change the fps to 24 but it doesn’t slow it down, it just takes away the extra frames.
    Im the old days I used to use Apple Cinematools
    Rick Lang replied 11 years, 5 months ago 2 Members · 1 Reply
  • Rick Lang
    March 29, 2015 at 1:57 pm
    Set your project timeline setting to 24 fps before you import. Then the frames shot at 60 fps will lay down on the 24 fps track as you want, playback at 24 fps from the project timeline.
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
