Activity › Forums › Apple Final Cut Pro Legacy › Still frame
Still frame
Posted by Tom Maloney on January 2, 2007 at 12:17 pmHi All, I am able to create a still frame in FCP, no problem. How do I export it to use as a menu in DVD Studio ? I tried exporting as still image and jpg under FCP export menu and DVD Studio will not reconigize it. Thanks for any help or explaining the correct flow to me ifI am all wrong
thanks again
Tom
Rafael Amador replied 19 years, 8 months ago 6 Members · 5 Replies -
Bouncing Account needs new email address
January 2, 2007 at 12:19 pmThere are many choices for various purposes. But the first few steps would be the same:
Park the cursor on the frame you want to export.
Then:Step 1: File> Export> Using QuickTime Conversion… “Save” window appears
Step 2: Format> Still Image
Step 3: Options… > Format: (choose PNG, PICT, JPEG, Photoshop etc.) > OK
Step 4: Name your image, Set location (disk, folder, desktop) for your new still. > Save -
Sammet
January 2, 2007 at 2:33 pmHi all,
I really need you help.
I have a lot of video footage that I want to convert to still images. I have both iMovie and FCP and the process of making the still frames are quite easy, but which deliver best result in terms of quality? Is there any other program that makes it better?
I am also wondering if there are any tips or tutorials on how to edit these still frames in Photoshop.
Finally if I know in ahead that I will use frames from my videos for still images, what should I bear in mind in terms of camera settings, light and MiniDV cassettes? I shooot on Canon XM2.
Thanx for help
Sammet -
Thaxter Clavemarlton
January 2, 2007 at 4:03 pmDV footage captured in any editing program will give you the same quality on export.
The problem is that using a “still” exported from a video camera will only have limited resolution (approx. 720 x 540 pixels @ 72 dpi).
This can be very low quality when used in printing.
There are some third-party applications that can raise the perceived quality of these images.
I’ve seen pxl SmartScale recommended many times.
https://www.codesco.com/Products_and_Services/Extensis/pxl_SmartScale/pxl_smartscale.html
This one’s a popular choice, too:
https://www.imaging-resource.com/SOFT/GF/GF.HTM
Here’s a link that tells how to try this kind “up-rez/interpolation” technique using only Photoshop CS.
https://www.interpolatethis.com/
Although I’ve tried it and did not get any tangible results.
As far as tips for using Photoshop, there are many tutorials (many must be purchased) available for that application, most of which can be found with a Google search.
John Fishback
January 2, 2007 at 7:28 pmHere’s another uprez program to consider, Genuine Fractals. They claim you can uprez 800%!
https://www.ononesoftware.com/detail.php?prodLine_id=2
John
Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
Pro Tools HD, Yamaha DM1000, Genelec Monitors, ISDN -
Rafael Amador
January 3, 2007 at 2:28 pmIf you don’t go to resize you don’t have to care about interpolation, and if you go to treat the images in Photoshop, export the files in this format. If you want to treat the images, unles are lanscapes or pictures without movemenet, you should deinterlace the still frames. I would recommed you to do that with a good filter in FC, because the de-interlacing filter in PH is not one of its highlights.
Salud,
Rafael
