Activity › Forums › Apple Final Cut Pro Legacy › Still can’t figure out how to get a decent credits scroll out of FCP
  • Still can’t figure out how to get a decent credits scroll out of FCP
    Posted by Defunkt on March 3, 2006 at 10:21 pm
    I’ve tried this so many ways now.
    1. FCP key framing a PNG/TIFF/JPG/GIF so that it’s moving 120 lines per second
    2. Field dominance lower/upper/none
    3. Boris3D (problem on its own because I can’t get a clip longer than 1m5s)
    4. Flash
    5. After Effects
    I’m creating a project where the end user will be viewing it on a PC so it needs to be crisp. It’s looks like the text is jumping up and skipping lines, just not smooth, not acceptable.
    This has been an issue for a while, previously we used flicker filters and putting a slight blur on the text for drafts, this will not work for the end product.
    Any help/suggestions?
    m
    David Smith replied 20 years, 7 months ago 3 Members · 3 Replies
  • Gunleik Groven
    March 3, 2006 at 10:47 pm
    First you’ll have to be in a non-interlaced square pixel environment. Then…
    Sorta depends on compression and resolution vs computer.
    Gunleik
  • Defunkt
    March 3, 2006 at 11:03 pm
    Can you give an example of a non-interlaced square pixel environment?
  • David Smith
    March 4, 2006 at 3:44 am
