Activity › Forums › Apple Motion › Still can’t export with transparent background
  • Still can’t export with transparent background
    Posted by Kay Ghey on May 2, 2017 at 1:04 am
    Hi guys,
    I’m a long time lurker but have finally achieved a level of frustration that’s driven me to creating an account.
    I’m spent hours today scouring the internet for some new solution to exporting out of Motion 5 with a transparent background.
    I’ve taken all the steps that I could find:
    1. Background settings to transparent
    2. Exporting in Proress 4444
    3. Export set to “Color + Alpha”
    and despite my best efforts, I still can’t find a way to get it into FCPX with a transparent background.
    I’ve also tried saving the project file and pulling that into FCPX but can’t seem to figure that out either.
    Any help you guys could offer would be life saving at this point.
    Kay Ghey replied 9 years, 3 months ago 4 Members · 14 Replies
  • 14 Replies
  • Mark Spencer
    May 2, 2017 at 1:53 pm
    Kay, I just tested those exact settings and it works perfectly. I exported a ProRes 4444 movie with alpha and imported into FCP X and the alpha channel in intact. Perhaps post screenshots of your canvas in Motion (with the background set to transparent), a shot of your export settings, and a shot of the clip in FCP X connected over a video clip or image so we can see the transparency or lack thereof.
    Mark
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Robin S. kurz
    May 3, 2017 at 8:18 am
    Exactly. When in the canvas hit ⇧T. Do you see a checkerboard pattern where you expect your transparency, a lá Photoshop? If not, then there is something wrong with your project settings, there’s a rogue layer or the likes. If you DO see it but aren’t getting your alpha with the export settings as described above, then I for one am stumped…
    When in doubt, copy/paste everything into a brand new project and check matters there (hitting ⇧T before pasting).
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Kay Ghey
    May 13, 2017 at 10:39 am
    Hi guys,
    Thanks so much for the time and attention. I’ve still got nothing. At present, here’s my canvas and export settings.
  • Kay Ghey
    May 13, 2017 at 10:45 am
    And here’s the clip imported into FCPX.
    I’m just baffled. The alpha layer doesn’t seem to show in FCPX and I also have black backgrounding if I open or view it in VLC or quicktime (not sure if that matters.
    Thanks for putting eyes on this, guys. I’m pretty well stumped. I keep trying new export settings and just don’t seem to have something in the right place.
  • Bret Williams
    May 14, 2017 at 3:16 am
    Have you tried it with the premultiply box off? That would be the preferred setting. That would be a straight alpha matte. Also check your project settings in Motion. Isn’t there a setting in there to render a solid background o something like that? Not at my computer right now…
    _______________________________________________________________________
    https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
  • Robin S. kurz
    May 14, 2017 at 10:25 am
    Actually, there is not globally preferred alpha, be it straight or premultiplied. In the end, if the math is done correctly (i.e. the interpretation is set correctly), then both will deliver perfectly fine results. Some NLE in fact don’t even accept or recognize straight alphas, so at least in that context you’re safer going matted. But fortunately in the case of FCP it’s irrelevant.
    So you’ll simply want a) check your project settings in Motion as Bret said and make sure the background isn’t set to SOLID. Because then you can render all day long with any given setting and you’ll never get your alpha.
    Then b) check the clip settings IN FCP how the file is being interpreted, i.e. make sure it’s set whatever it is you used and not being ignored (which is actually extremely unlikely with a file coming from Motion).
    If EVEN THEN it’s not working, which would be very odd, then you’d have to post the clip or a frame somewhere so one could have a look.
    – RK
  • Kay Ghey
    May 28, 2017 at 9:15 pm
    Hey Robin,
    If I could ask, where are you checking that box in FCPX that describes alpha handling.
    I had to walk off from this project for the last month and I’m just settling back in and still banging on this. I’m sure it’s something mundane I’m doing wrong, but I’ve gone down the checklist and am just still not getting results.
    (I’m back on generation in FCPX, but where is that same alpha handling box you screen shotted available in 10.2.3?)
    Thanks Robin
  • Kay Ghey
    May 28, 2017 at 9:25 pm
    Ok I’ve discovered that box.
    Still jiggering.
  • Kay Ghey
    May 28, 2017 at 9:56 pm
    Hi Team,
    It’s still just not budging for me. I’ve gone ahead and recorded and uploaded a quick screen cast to see if anyone can spot me making the mistake, located here.
    https://www.youtube.com/watch?v=p8hxl5HmE5s&feature=youtu.be
    Note, I went back and immediately changed the “Alpha Handling” to “Straight” right after I cut the video.
    I feel like I’ve done everything right and am just not getting it to work…
    Thanks guys. you’re invaluable.
  • Kay Ghey
    May 28, 2017 at 10:09 pm
    Sweet mother of Jehovah…
    Alpha channel is non-functional when FCPX display settings are set to “Proxy Media” it would seem…
    I think I just figured out where a week of my time went…
