Activity › Forums › Apple Final Cut Pro Legacy › still banding: now what?
Posted by Andwon on August 29, 2007 at 10:27 amrecently I’ve been posting about issues with scaling nested sequences.
nested sequence/banding.. still
https://forums.creativecow.net/readpost/8/952422nested sequence probs
https://forums.creativecow.net/readpost/8/951392eventually for broadcast
https://forums.creativecow.net/readpost/8/951248And yall graciously offered solutions which i tried; to no avail. so I did a simple test
to try and nut this out. capture digibeta source tape as 8bit uncompressed PAL and drop it into a 8bit uncompressed PAL timeline. scale it to 30%. Viewing it on a monitor, guess what, banding still occurs@!what could be the source of the problem? the solution is………..? what else do I do to track down the problem? All looks fine until scaling down. holy maroney!
the system:
FCP 6
Mac Pro Dual Core 2.6 GHz
5 gig RAM
Kona 3-andwon
Nils Crompton replied 19 years ago 6 Members · 10 Replies -
Walter Biscardi
August 29, 2007 at 11:07 amStarting new threads every few days for the exact same issue does two things.
Annoys the hell of us to keep seeing your same topic in multiple threads posted by the same person.
Makes it difficult for people to follow along to see what has been suggested to solve your issue since you keep breaking up your issue into multiple threads.
One thread per issue makes it easier for everyone to help you.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Jerry Hofmann
August 29, 2007 at 11:18 amAs I said earlier. 8 bit video will always show up with some banding. You need to shoot and edit 10 bit video. And you also should be using the high quality motion processing set from the sequence’s settings’ video processing tab.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Andwon
August 29, 2007 at 12:44 pmMany thanks for your help kind sirs; especially for your patience.
jerry i tried the normal, fastest (linear), and best with very little difference.
i’ve never experienced (or noticed?) this issue in previous versions of final cut.
i guess it’s a bit dissapointing since 2 continuous streams at 30%
will be playing throughout the program.is the only solution to having decent looking vision for this program, is to reshoot and cut it in 10bit? oucheehuahua!
many thanx,
-andwon
Jeff Coleman
August 29, 2007 at 2:03 pm[Andwon] “is the only solution to having decent looking vision for this program, is to reshoot and cut it in 10bit? oucheehuahua!”
I don’t believe you can shoot digi in 10bit. I believe its an 8bit compressed recording device.
Instead, capture in a 10bit codec like Apple 10bit uncompressed, but even it has some issues.
Here’s some links regarding Sheer Video codecs
https://www.lafcpug.org/reviews/review_sheer_video.html
Sheer offers a free tryout
https://www.bitjazz.com/en/products/sheervideo/
At times I’ve had better luck scaling with something like Boris Continuim plug-ins, but I don’t recall it ever fixing a banding issue.
let us know what you learn
(on this thread, please) -
Andwon
August 31, 2007 at 7:21 amUm,
I captured digibeta in 10bit PAL. scaled it to 30% in a 10bit PAL timeline. I don’t really see any improvement, slight if any improvement at all.
I’ll try another capture monday with some other footage to verify.my small mind is quite amazed that it’s not possible to scale video downward without distortion in the 21st century with FCP6.
thanx for the interest and help
-andwon
Nils Crompton
August 31, 2007 at 9:09 amThe normal way to avoid banding when manipulating images is to add a bit of gaussian monchromatic noise to the image in the step before whatever it is you do that causes banding. you have to play around to get the right balance of noise/banding.
Its the same principal as dithering in gif images…
nils
Andwon
August 31, 2007 at 9:23 amok nils, i’m up for anything. is this done with FCP filters? you got some instructions to lay on me? the only thing i’m doing at this point is scaling the video down to 30%, so there’s no before, if you know what i mean-andwon
“add a bit of gaussian monchromatic noise to the image in the step before whatever it is you do that causes banding”
Nils Crompton
August 31, 2007 at 9:37 amOK,
If it happens as you scale the image then you can apply the noise to the clip at this stage – no need to nest it or pre-process it.
In FCP use: Effects/Video Filters/Stylize/Add Noise
Set to, Gaussian, monochrome, rest to default, then set amount to 0.01 and increase until it eliminates banding but before you notice it.
Not sure if you need to auto animate or not, I’d say if you can see the noise then you need to animate it – or it will appear unnatural, otherwise leave it as static.
This is a trick that designers use all the time when making gradients in 8-bit design files. It is worth remembering that most broadcast work will end up being displayed as 8-bit ultimately (i.e. high bitrate MPEG2) so working in a 10-bit workflow doesn’t guarantee that the end viewer wont get banding. I’d say the reason you are getting banding is because your image is ‘too clean’.
Cheers,
Nils
