Activity Forums Maxon Cinema 4D Stick Texture Tag
  • Stick Texture Tag
    Posted by Justin Puda on January 9, 2009 at 10:50 pm
    Hello,
    I am trying to use frontal mapping with a stick texture tag on a flat model of earth(like a map). The tag makes the texture stick perfectly during any deformations it goes through. However, as soon as I move my camera the texture slides off the model. How can I make this texture stick while the camera is moving as well? When I try to use UVW mapping it maps the texture to the sides of the model, instead of to the faces where I need it.
    Justin
    Justin Puda replied 17 years, 8 months ago 3 Members · 3 Replies
  • Brian Jones
    January 10, 2009 at 2:37 am
    I don’t think Stick texture with Frontal would work, try Flat mapping
  • Adam Trachtenberg
    January 10, 2009 at 4:12 am
    Set the tag to frontal, then right-click and select “generate UVW coordinates”.
  • Justin Puda
    January 10, 2009 at 6:37 pm
    Adam & Brian,
    Thank you both so much for all your help. Adam – the generate UVW worked perfectly. Thanks guys for always helping a noob.
    Justin
