Activity › Forums › Maxon Cinema 4D › stick texture on multiple objects
  • stick texture on multiple objects
    Posted by Hymn Wong on October 14, 2009 at 4:30 am
    hi all,
    is there a way to stick a texture to multiple objects,
    and when moving 1 object it, the texture will stay at it is?
    Please see reference:
    The problem here is, when moving the top right object, the texture remains the same position, but i want it to move along with the object.
    Actually I want to apply an animated sequence texture to it,
    i know there must be an easy way to do it..
    but just can’t figure out how..
    Thanks for replying in advance!
    Hymn Wong replied 16 years, 11 months ago 1 Member · 1 Reply
  • Hymn Wong
    October 14, 2009 at 5:21 am
    never mind, i solved it with Fix Texture set to Straight in the object tag of the cloner object 😉
