Activity › Forums › Maxon Cinema 4D › “Stick” flat projected texture to Text Object (again…)
Posted by Corrado Carlevaro on March 30, 2010 at 1:05 pmHi,
I’ve read all posts but I didn’t find a solution to that silly problem: I apply a color gradient to the Cap of a Mograph Text Object (flat projection) but when I animate the Text position with Effectors the gradient “slips” from Text, or better, it stays in its “absolute” position. Any solutions?
Thanks in advance
CorradoJames Michaels replied 16 years, 4 months ago 3 Members · 7 Replies -
Jeremy Allen
March 30, 2010 at 2:02 pmI could be wrong, but I think that is what Flat projection is supposed to do..
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6C4D 11.5
AE CS3
FCP 6.0.1 -
Corrado Carlevaro
March 30, 2010 at 4:17 pmWell, I could be wrong too, but this is what Camera or Frontal projection should be supposed to do. I mean, there’s not a way to apply a simple gradient or whatever to a not-editable text and then animate that text?
Jeremy Allen
March 30, 2010 at 4:26 pmI’ve never had to use it, but I know there is a “stick texture” tag.. Maybe you should look into that.
AE CS3
FCP 6.0.1 -
Corrado Carlevaro
March 31, 2010 at 3:13 pmThank you, but as far as I understand that tag is working with deformers and polygonal objects. For now I made the Text a polygonal object and solved this way.
Corrado -
James Michaels
May 5, 2010 at 8:47 amI had exactly the same problem and it bugged the hell out of me for ages.
Some helpful person over at mograph suggested the following which works but is a little fiddly
Use a Connect Object with your mograph text object with the following hierarchy:
Fracture Object > Connect Object (with texture tags) > Extrude Object > Splines.
or
Fracture Object > Connect Object (with texture tags) > Extrude Object > Text
Some examples below:
https://homepage.mac.com/tcastudios/tempfiles/mogradient.c4d.zip
https://homepage.mac.com/tcastudios/tempfiles/mogradient2.c4d.zip
Corrado Carlevaro
May 11, 2010 at 9:01 amThank you for your suggestion, I’ll try it as soon as I can. I was just wondering why one would need such workarounds for an apparently common and simple situation, a flat projected texture on a moving object!
Corrado -
James Michaels
May 11, 2010 at 4:38 pmNo idea – something to do with each item not actually moving in space, rather being ‘effected’ by an effector….. Who knows…. not me!
