Stereoscopic output via Kona 3G
does anyone know how can I get stereoscopic 3D output out of Kona 3G via (preferably) Quicktime API? I am interested in full resolution right/left channel output, so I only need to send left stream via first SDI out and right via the second. But sadly, the Quicktime API doesn’t seem to support this. Has anyone an idea how can I do it? The device is switched to 3D stereo, but from Quicktime’s point of view there is still only one video output component. I wonder if there is some codec/component (like AJAMuxer ?) which can I use in order to output 2 streams via 2 SDIs.Thanks, I’d appreciate any help.
