Activity Forums Panasonic Cameras Stereoscopic Calculator technical information help required
  • Stereoscopic Calculator technical information help required
    Posted by Clinton Rocksmith on September 18, 2009 at 12:28 am
    Hi there,
    I’m about to release version 1.0 of my 3D stereoscopic calculator software. I’m just finding out the settings for each of the main cameras that would use this.
    For HVX series of cameras I need the following information:-
    Actual Width of the sensor (mm)
    Actual Height of the sensor (mm)
    Actual Pixel Width (1920? or something else?)
    Actual Pixel Height
    Actual Pixels and sizes are required for the DOF calculation that is required to capture stereoscopic images. So if the camera captures at 4,325 (width) but then does a conversion to 1,920 I will require the original number.
    This software uses a technique which assists 3D to be shot with ebb and flow. You can control the THROTTLE of the 3D effect (the amount of 3D) so that it moves with the story, just like it should be. Adding art to the science.
    The software is free for all to use. So go forth and shoot.
    Available at https://www.clintonrocksmith.com
    Please post your technical info, here for me.
    3D stereoscopic software development
    http://www.clintonrocksmith.com
    Clinton Rocksmith replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
