Activity Forums Maxon Cinema 4D Stereo3D in Cinema – How do you do it?
  • Stereo3D in Cinema – How do you do it?
    Posted by James Doherty on March 3, 2011 at 4:07 pm
    Stereo 3D workflow headaches!
    Currently I use a 3D rig in cinema, sort of roughly estimating the 3d effect using the reference planes from the rig. *
    Render out the left and right eyes, bring it into AE and send it out from there to a 3D TV I have hooked up.. THEN check out the stereo effect.. Which often requires a bit of tweaking
    Make adjustments and re-render, re-import into AE every time it changes a bit..
    It’s slow and frustrating.. If I could send out my viewport to the TV directly then that would be perfect.. Anybody know if that’s possible?
    That way I could get that viewport to display side by side using a plugin and then send that out. Would enable totally live previewing of the 3d effect..
    I’ve considered getting a 3d monitor as my second monitor and just dragging the viewport to it but as I don’t know any way of getting proper full screen in c4d (without toolbars etc) then the effect wouldn’t line up 100% correctly.
    (If that’s not clear I mean that I would set my viewport to display as side by side then set the monitor to look for a side by side signal.)
    There are plenty of other people asking similar questions online but I haven’t seen any answers that really worked.
    Are any of you doing stuff in 3d with c4d? How do you do it?
    James
    *The rig I’ve been using is pretty good and was free, if you intend on doing any c4d stereo3d it’s worth a look, some good video explanations too: https://www.svoigt.net/
    James Doherty replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
