Activity › Forums › Apple Final Cut Pro Legacy › stereo to 5.1
stereo to 5.1
Posted by Jesenia Ramirez on May 8, 2008 at 6:54 pmMy company wants to re-release their dvds in 5.1 surround. How would I go about using the existing stereo audio and creating 5.1? Also, how would i set up my iMac to monitor 5.1?
Reid Caulfield replied 18 years, 4 months ago 4 Members · 3 Replies -
Russell Lasson
May 8, 2008 at 11:19 pmYou should try using the audio out put (headphone jack) with it set to optical. Then with the right cable, you should be able to go out to a home theater 5.1 system.
Or you can get a firewire audio box. There are a bunch of different kinds.
-Russ
Russell Lasson
Kaleidoscope Pictures
Provo, UT -
Arnie Schlissel
May 9, 2008 at 2:47 pmI have a friend who specializes in this. If you have the original audio stems it might be possible to remix into real surround sound. If all you have is a stereo mix, it can be sort of faked. If you want to get my friend’s contact info, email me off list at arniepix (at) arniepix (dot) com
Arnie
Finally out of post! Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Reid Caulfield
May 10, 2008 at 1:44 amI do a lot of this & would be happy to talk to you about it. Lots of ways to go with it depending on budget, available materials, etc. Contact me off list at reidwc@sbcglobal.net.
Reid C
