Activity Forums Apple Final Cut Pro Legacy Stereo Pair multiple clips at once?
  • Stereo Pair multiple clips at once?
    Posted by Daniel Miller on October 13, 2007 at 7:29 pm
    I have a bunch of clips laid out on my timeline, and I need to stereo pair them. I know I can go through the timeline one by one and hit option+L, but if I select multiple clips I cant stereo them all at once. Even when I go to the menu modify>stereo pair the option is grey’d out. Is there a way I could select all the clips on my timeline and stereo them at once?
    They are captured on a separate audio recorder onto a flash card and I bring the files into FCP, I only mention this because I assume someone would tell me to capture in stereo to begin with. Thank you for any help you can lend.
    Steven Gonzales replied 18 years, 10 months ago 2 Members · 1 Reply
  • Steven Gonzales
    October 13, 2007 at 8:12 pm
    Someone might have a better idea, but you could put all your audio in a bin, make sure the Audio column is showing, export a batch list, global replace to change all the “2 Mono” in the batch list to “1 Stereo”, reimport the batch list, and try to reconnect to the clips.
    I haven’t tried it, but it might work
