Activity › Forums › Adobe Audition › Stereo audio problem with FCP 7
  • Stereo audio problem with FCP 7
    Posted by Mitch Jordan on February 12, 2013 at 6:50 pm
    I’m transitioning to Adobe since the death of FCP 7, and I’m learning to use Adobe Audition in place of Soundtrack Pro. I’ve created a multitrack mix in Audition, and now I want to bring the final mix into Final Cut Pro. I exported a multitrack mixdown from Audition as a .aiff file. It should be a stereo file, however FCP sees it as mono. I reopened the mix in Audition and Quicktime Player 7 and both see a stereo file. Does anyone know why FCP sees the file as mono?
    Scott Clements replied 13 years, 5 months ago 3 Members · 3 Replies
  • Mitch Jordan
    February 12, 2013 at 7:48 pm
    Ok, I think I solved my own problem. I was dragging the audio to the timeline in FCP. If you double click the clip into the viewer, you see there are actually 2 mono files in an .aif or 1 stereo pair in a .wav. Do an overwrite edit, and all’s well. Apparently dragging it to the timeline only brought one channel.
  • Joseph W. bourke
    February 14, 2013 at 6:41 pm
    Thanks for the solution, Mitch. This could come in handy for a lot of people.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Scott Clements
    April 9, 2013 at 11:48 am
    I don’t think the overwrite method is the solution, because when I loaded a stereo aiff from Audition into FCP 7 viewer and overwrote to the timeline, there was a slight phasing issue (my mix was one track of a presenter speaking) However, when I brought in a .wav stereo file from Audition and did the same, the phasing was gone. I heard Larry Jordan say that it’s better to export .wav files
    Film Editor, London UK
    http://www.scottclementseditor.com
