Activity › Forums › Apple Final Cut Pro Legacy › Stereo audio issue
Stereo audio issue
Posted by Bill Portune on August 3, 2005 at 11:26 pmI’m having a problem with stereo music ending up mono after render, anyone else having this issue and/or know of a fix?
Bill Portune
The Chesapeake GroupG5 DP 2G, 10.4.2, QT 7.0.1, 1.5GB RAM, FCP 5.0.2, Io (2.0), Kona2 (1.1.2), UL4D, Huge U320R
Bill Portune replied 21 years, 1 month ago 2 Members · 4 Replies -
Rick Aplin
August 4, 2005 at 9:17 pmHaving the same problem on two seperate set ups – only noticed it after an audio mixdown. I think it may be a bug, but need to try new audio options in the sequence settings – it automatically sets to default, but also has options for stereo mix and dual mono, I’m not sure what the default option refers to. Will experiment.
Rick Aplin
August 5, 2005 at 10:17 amWell Bill, just tried setting the config pop-up of audio settings to stereo mix ( this is in the general tab of sequence settings ) and it seems to have worked – getting full stereo music mix now from my sequence. However I only tried a short render and have yet to do a full audio mix of my sequence to see if that works. interestingly, I tried the audio setting back at default after the test and that too seemed to mixdown in stereo OK – could be a preference setting thing.
Bill Portune
August 5, 2005 at 7:25 pmChanged from default to Stereo mix, but still renders out mono. I have 44K music and other stereo tracks with effects applied – all render to mono.
As a work-around I have to ungroup the stereo pair prior to rendering.
