Activity Forums Adobe Premiere Pro Stepping into Real-Time editing hardware-advice needed from the experts
  • Stepping into Real-Time editing hardware-advice needed from the experts
    Posted by Shane Mcconnell on March 4, 2010 at 5:15 am
    Hello,
    I have recently stepped up my video production from mere serious weekend hobbyist, to my full-time job catching wind of some of my video projects and fast-tracking me into a wide range of creative corporate videos.
    This is great for me, because I always dreamed of producing video for pay!
    I am needing to upgrade my CS3 / CS4 Premiere based editor to a “Real Time” system. No more rendering previews please! I also noticed several of these solutions boasting “live preview of animations” in After Effects. This all speaks wonders and whispers of streamlining and SPEEDING UP my workflow.
    I shoot with a Sony V1U in 1080i to a Sony HDR-60. The HDR-60 stores the files as .M2T files to the disk and with a click and a drag over to my RAID 0, I am sorting and cutting footage in minutes inside Premiere. The playback of the HD footage in CS3 is smooth, crisp and clean. Once I cut it into the timeline I must render to playback (or anytime after changing any FX, fades, etc). In After Effects I am stuck with the RAM preview to view my animations.
    I do own Adobe CS4, or as I call it around the studio- Satan’s Software. I am really tired of the quirky, choppy, time wasting problems with this program. So I stick with CS3 to get anything completed.
    I have looked at several of the approved and supported Real Time 3rd party solutions/vendors Adobe has listed on it’s website for Premiere CS4. It would appear that the Matrox RT.x2 and Blackmagic cards are within my budget.
    My question(s) to you fine folks are:
    Do I really need to spend $1200 for the Matrox RT. X2 card to gain this “preview free” or real time workflow? I will never have the need to capture any footage.
    Or will one of the Blackmagic cards- like the Decklink or Intensity give me this real time performance gain I am looking for? https://www.blackmagic-design.com/products/decklink/
    Intensity for $199 !! https://www.blackmagic-design.com/products/intensity/
    I have read on the website about the Intensity giving me a real time preview on my playback monitor via the video out (HDMI in this case) inside After Effects of Animations. For playback in Premiere Pro it boasts “playback in the timeline without rendering.”
    Here is the big one: Does anyone know or have direct expereince if this only stands for footage that was captured VIA the Intensity/Decklink card(s)? Or does this cover all SD and HD footage, most importantly jiving with my HDV footage that is recorded straight to my HDR-60?
    I welcome all advice and tips!
    Thanks in advance!
    My system specs:
    -Windows XP 64 bit
    Service Pack 2
    -Motherboard: Asus M3A78-T
    -CPU: AMD Phenom II X4 940
    (Quad Core 64bit, 3GHz)
    8GB of DDR 800 RAM in ganged mode and the pagefile (virtual memory) in Windows was set to 12GB
    -Operating System, Programs and scratch drive: Seagate ST3500320AS (500GB, 7200 rpm SATA, 3Gb/s, 32MB cache)
    Video storage / working drive: Western Digital WD7500AAKS x3 (750GB, 7200 rpm, SATA, 3Gb/s, 16MB cache) in RAID 0
    Display adapter: ATI Radeon 4850 X2- Quad Display (CrossFireX is disabled to enable use of all four monitor ports)
    Driver: version 10.2
    Direct3D version: 6.14.10.0728
    OpenGL version: 6.14.10.9551
    ( I was testing out a nVidia Quadro FX3400 but I cannot get Adobe drivers for a 64bit system for this card 🙁 )
    Camera: Sony V1U, the footage is HDV 1080i – recorded to a HVR-DR60 which stores the files as .M2T (1440×1080)
    Andy Prada replied 16 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Christo Leone
    March 4, 2010 at 8:00 am
    I’m also looking into buying a blackmagic card. Have read up on the other things but the Blackmagic seems like the way to go. Would love to hear form someone that already has the card and can give us some accurate responces and not worked up marketing hype.
    Thanx
    Cheers vir eers
    ~ You are only limited by you’re ignorance ~
  • Mike Velte
    March 4, 2010 at 11:26 am
    I would be concerned about your OS…XP 64 is not an Adobe certified OS for CS4 or CS3.
  • Shane Mcconnell
    March 4, 2010 at 12:01 pm
    I was running brand new build of Windows 7 64bit, all the latest everything (drivers, updates) about 35 days ago and I couldn’t even get CS4 to launch. I would execute and whammo- big fat crash w/ report. I sent about 40 of those crash reports with my email info and a description almost everytime so “one of the Adobe Engineers could review and possibly contact” HA- that will be the day. Anyways I went through the painful process of uninstalling and rolling back to XP 64bit..haven’t had a crash yet.
  • Jeff Pulera
    March 4, 2010 at 3:37 pm
    Hi Shane,
    Long-time RT.X2 user here, and producer of the RT.X2 Revealed training. While I haven’t tried Black Magic myself, it’s my understanding that the RT.X2 (and AXIO) are really the only hardware options for Premiere that actually provide TRUE “realtime” effects.
    In other words, some vendors promise “realtime previews” which maybe means that even though the clip has a red bar, it will play back smoothly. But in the end, any final output will require that red bar segment to first be rendered. So if encoding to MPEG-2 for DVD, the red bar segments first need to render, then the timeline can be encoded to MPEG-2, a two-step process.
    With Matrox RT.X2, say you have a one hour clip with Matrox Color Correction filter applied. There will be no red bar. If you wish to encode to MPEG-2, then that is all the time it takes, there is not additional time to first render the entire one hour color correction. You may be able to export the entire hour program, with effects, in 15 minutes for instance.
    Doing a Premiere-native color correction (red bar), it may play back smoothly, but come export time, you take the penalty in render time. Like the old saying, “You can pay me now, or pay me later…”. Either way, you’re gonna have to render.
    The RT.X2 LE is $795, somewhat less than the $1200 you mentioned, and works well with CS3, but note it will not support XP 64, you would need XP Pro 32-bit with CS3.
    Another option is to wait for the next version of Adobe which promises realtime performance, but I don’t know when that will ship.
    Jeff Pulera
    Safe Harbor
  • Alex Udell
    March 5, 2010 at 3:57 am
    Jeff is right…
    Other solutions allow for Inout and output of signal in PPro.
    The Matrox products are the only real solution for genuinely enhancing creative performance during the editing session. They do this by leveraging a combination of their own chips plus those of a paired qualified graphics display adapter.
    However, you do find yourself at the crux of an interesting point in PPro history. Adobe has been showing it’s forthcoming “Mercury Playback” Engine. This is Adobe’s implementation of leveraging graphics hardware to do more in real time in PPro. I would guess it would be in PPro CS5, as they’ve been talking about it and demonstrating it. This has not been formally announced, however.
    This means that because your workflow is essentially filed based (.m2t) there is no need for signal capture and output. If the Mercury playback engine uses the graphics hardware for acceleration one of the chief advantages of the current Matrox line gets reduced. I love Axio and RT.X2. compared to the long render times of the FCP suite I currently find myself in, I miss them a lot. But keep an eye on where things are going and spend your money wisely.
    Hope that helps,
    Alex
  • Shane Mcconnell
    March 5, 2010 at 5:24 am
    Great- thank you for the responses so far! I am thinking that a Quadro FX 3800 card may be the way to go- this way I am supporting Adobe’s Mercury playback engine whenever it happens to surface..and picking up a performance gain in the interim. A Matrox card does sound very tempting tho. I really have to sit and think about this!
    The partner certified drivers for the Quadro cards for Adobe are only 32bit OS supported. The nVidia “Performance drivers” and others for the Quadro support 64bit OS’s. Will I see the same results or performance gains with the non-partner certified driver??
  • Andy Prada
    April 2, 2010 at 8:14 pm
    Isn’t it interesting how everything seems to have come full circle? I still work with Avid (oh yes!) having done one of the first training courses at the National Film School in UK way back in the last century.
    Avid was castigated by some because it relied on expensive proprietry hardware (cards, etc) that pushed it well outside the affordability path of many corporate and non-broadcast video makers. “Too expensive!” everyone cried as they soldiered on with less than perfect functionality and wrinkles to boot with various versions of alternative software. (myself included I might add)
    Now we may be on the cusp of having so called Mercury engines that are only thus because they have a couple of mega quadro thingamajigs supporting them at a cost of $XXX and need a cpu the size of the pentagon to power them.
    Wistfully I do wonder if we’d all be better off with a steenbeck and a little more imagination. Or maybe perhaps I should retire.
